how to wire a push button start
Started by AjOmega, 25 July 2011, 16:14:56
AjOmega
How would i wire a push button start to a cadillac catera
without having a key.. :)
Osprey
"Hot wiring" to bypass the ignition lock isn't rocket science but it would no doubt contravene OOF rules to go into detail.
However one of the car's ECUs needs a successful read of the immobiliser chip before it will allow the engint to start.  The immobiliser chip is also contained in the key which, by the sound of it, you don't have.  Getting around that is going to be much more difficult.
And much less ethical to publish on a public forum.   ;)
I feel like a military academy. Bits of me keep passing out.
AjOmega
i have the key to the car i just broke the back of the ignition that goes into the igntion switch i was just thinking a push button would ve been cheaper then going to buy a whole new ignition.
Quotei have the key to the car i just broke the back of the ignition that goes into the igntion switch i was just thinking a push button would ve been cheaper then going to buy a whole new ignition.
You would have to tape the key, or the transponder chip, to the side of the imoblisor transponder to get that part to work. You would have to have a switched ignition live, and a spring loaded "starter" switch.
All very easy to do, however, you would have no security and  I doubt any insurer would be prepared to cover you for theft, and if you didn't tell them and they found out ..........  :(
You would still need to have some kind of switch to turn 12v on and off. Might be easier to fix it, unless you are doing it for style purposes...
AjOmega
Yea i dont wont my car to get stolen so im just going to get the ignition replaced even tho its 200 U.S dollars lol  :y
Would have thought it would be cheaper to get a barrell & key from a breaker :-?
AjOmega
where would be the best place to get a barrel and key
No idea where to get one your side of the Atlantic, sorry.
Quotewhere would be the best place to get a barrel and key
Bit costly. Don`t know whether the omega barrell is the same, if so, one could be shipped from the UK I imagine
http://cgi.ebay.com/ebaymotors/1997-2001-CATERA-IGNITION-SWITCH-ASSY-USED-_W0QQcmdZViewItemQQfitsZModelQ3aCateraQQhashZitem5199eaa8bfQQitemZ350474643647QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
AjOmega
Thanks im going to consider buying that. its exactly what i need :y
QuoteThanks im going to consider buying that. its exactly what i need :y
It says "best offer" so good luck :y Unfortunately for you it wouldn`t be more than about $20-25 secondhand in the UK
AjOmega
Will I need to take a trip to the Uk for all the parts i need. :)
QuoteWill I need to take a trip to the Uk for all the parts i need. :)
Depends on what you needed ;D ;D ;D now, if you were in Orlando come Sept/Oct ::)
AjOmega
lol alright thanks for the help. :y
