HID's....
Started by 51M0N, 27 July 2011, 10:17:29
51M0N
I'm thinking of getting a set for my dipped beam (H1)
I've never touched these before so its new to me. easy fit?
if you wont use the original set (expensive) be sure to buy a set that doesnt give mid warning..
51M0N
Quoteif you wont use the original set (expensive) be sure to buy a set that doesnt give mid warning..
My mid doesn't work anyway  :(
QuoteI'm thinking of getting a set for my dipped beam (H1)
Yep. Source a pair of pre-face HID`s from a breaker complete with ballast pack (bulbs if poss) plus the connector and short piece of loom that goes to the ballast. just a case of fitting the HID`s on yours, splice the two wires from ballast plug (yellow & brown) into the existing same colours on your dipped beam plug, fit your level motors into the HID`s (plug & play). As you`ve already got H/L washers fitted.........job done
51M0N
I just noticed a complete h1 kit on teabay and thought id ask before buying  :D
QuoteI just noticed a complete h1 kit on teabay and thought id ask before buying  :D
MOT failure from 2012
51M0N
Wont be a problem.
Whats wrong with H1 bulbs though?
