Author Topic: TC & ABS  (Read 7451 times)
51M0N
  • Hull
TC & ABS
« on: 27 July 2011, 10:26:54 »
Since I got the car these have never worked. It doesn't really bother me as I like to drive without aids. However I do like things to work if they should..
I've checked the fuse for it and that's fine. however the dash bulbs don't illuminate and pressing the TC switch does nothing. Am I right in assuming the bulbs form part of the circuit and Perhaps try replacing/inserting these first?
Re: TC & ABS
« Reply #1 on: 27 July 2011, 10:31:22 »
I suspect they are permentlyy on and someone has therefore removed the bulb.
I would get the car on a good code reader and work out why and fix the problem
ABS lights not working is an MOT failure  :y
Re: TC & ABS
« Reply #2 on: 27 July 2011, 10:32:32 »
Should add, your car is the older 3 channel ABS system, which doesnt suffer the usual failure the later (98 on) systems are susceptible too
51M0N
  • Hull
Re: TC & ABS
« Reply #3 on: 27 July 2011, 10:34:13 »
So is having no cats, But that's never been a problem ;)
iirc its only a fail if it illuminates and doesn't go out.
I'll try some bulbs anyway when i work out how to removed the clocks.
Re: TC & ABS
« Reply #4 on: 27 July 2011, 10:36:48 »
fair enough - tame tester..
but officially if ABS fitted (obvious) then the lights HAVE to work.
Guide in the maint section on removing clocks.
Re: TC & ABS
« Reply #5 on: 27 July 2011, 10:38:57 »
and not that it matters to you, but :
http://www.motuk.co.uk/manual_340.htm
51M0N
  • Hull
Re: TC & ABS
« Reply #6 on: 28 July 2011, 19:01:58 »
Took the clocks out, easiest one to do ever  :D
put a bulb in the abs and tc slot,
Abs light comes on ans goes off, alls well
tc light nothing....
Any ideas?
Re: TC & ABS
« Reply #7 on: 28 July 2011, 19:12:57 »
tc light -
light should be OFF by default
going to ON when you press the TC button to disable the system
I take it you mean it wont illuminate whatever you do?
Guess you need to get it on a decent code reader that will talk to the ABS ECU to see whats up.
I reckon if it was faulty, the light should be on, so my 1st instinct is the switch may be faulty.
Re: TC & ABS
« Reply #8 on: 28 July 2011, 19:14:06 »
or the tc bulb is blown.
51M0N
  • Hull
Re: TC & ABS
« Reply #9 on: 28 July 2011, 19:14:53 »
tc light -
Tried a bulb I knew worked for certain, its supposed to illuminate when off irrc. didnt do anything at all. looked at the switch wiring seems fine and pressed it etc.
« Last Edit: 28 July 2011, 19:15:28 by Simon131188 »
51M0N
  • Hull
Re: TC & ABS
« Reply #10 on: 29 July 2011, 08:58:12 »
Its now becoming clearer. After some blind prick pulled out on me this morning and i had to bury my foot into the carpet the abs light came on and stayed on....
Time for a plug in.  ::)
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
Re: TC & ABS
« Reply #11 on: 29 July 2011, 21:16:30 »
Hi all,
the auto transmission was removed by the previous owner of my car and put into a manual one. TC doesn't work , my questions are : was there any electric connection between the transmission and ABS/TC block needed to proper operation? Can I use TC with manual gearbox?
cheers  Laszlo
C20NE - X25XE
Re: TC & ABS
« Reply #12 on: 29 July 2011, 21:27:59 »
Hi all,
cheers  Laszlo
The engine, ABS and gearbox all chat to each other on a canbus. Not sure if the work you've done would stop TC working
51M0N
  • Hull
Re: TC & ABS
« Reply #13 on: 31 July 2011, 12:29:25 »
Hi all,
cheers  Laszlo
Make your own bloody topic!  >:(
plugged mine in to find the abs fault but it doesn't store anything, am i right in thinking its the old hall sensor type?
Re: TC & ABS
« Reply #14 on: 31 July 2011, 13:13:25 »
Hi all,
cheers  Laszlo
No need for that mate. He`s a relatively new member and not in the UK.
Thank god the majority of us haven`t got the same attitude :-X
