Author Topic: urgent cid display  (Read 3630 times)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
urgent cid display
« on: 05 August 2011, 15:59:53 »
when pairing screen in display mode do i need car code as well please
pscocoa
Re: urgent cid display
« Reply #1 on: 05 August 2011, 16:06:01 »
everything seems fine but flashing display safe but it is the original cid
« Reply #2 on: 05 August 2011, 16:40:11 »
please tell me your not using "My Naff Code Reader"  :-/
pscocoa
« Reply #3 on: 05 August 2011, 17:09:58 »
no Tech 2 but did not have car security code with me - I thought I did not need it if original display (after repair) going back in (replacing another screen installed 4 years ago which has gone faulty again).
It is flashing Display Safe - all GID stuff is working but not maps as yet - this happened last time due to gray lead not pushed home I think.
Hopefully I can get this sorted tomorrow - but question is will insertion of 4 digit car pass code cure the Display Safe - I just cannot remember using this code last time i.e. 4 years ago.
The more worrying issue is the black screen on maps - not sure code will sort that one - but one step at a time.
edwardmickey
  • Milton Keynes
« Reply #4 on: 05 August 2011, 21:12:05 »
The CID needs pairing with the head unit (with the same car pass).
The black screen menu just needs the setting adjusted with the Tech2
« Last Edit: 05 August 2011, 21:12:53 by edwardmickey »
pscocoa
« Reply #5 on: 05 August 2011, 23:20:11 »
thanks edwardmickey - will try and sort tomorrow - now have car pass
pscocoa
« Reply #6 on: 06 August 2011, 13:33:20 »
car security code sorted the Display Safe problem so I have a functioning screen in grey, black, orange as normal - but no colour maps - just a black screen showing the Menu and Repeat tabs in black and white. Must be a lead problem unless there is a Tech 2  fix for this.
Edwardmickey - will pm you on this point.
    • 530D M Sport, 330i Coupe
« Reply #7 on: 07 August 2011, 17:58:28 »
Check the 12 Pin plug.
Big_Al
« Reply #8 on: 07 August 2011, 18:08:51 »
That was the problem with mine when no maps were showing  :y :y
pscocoa
« Reply #9 on: 07 August 2011, 20:55:53 »
thanks - that does look to be culprit now
pscocoa
« Reply #10 on: 19 August 2011, 20:01:32 »
the problem was not the lead but a "vehicle identity issue" and poor knowledge of Tech 2 - maps now working but have lost top line data of screen which is the area that should have notices such as "Navi Inactive" on it - hope to get there in the end.
The successful part of this saga is that I sent the faulty screen to a German company (guy speaks no English whatsoever) on the Monday and it was back repaired by Friday. Shame I could not do this justice with VX dealer fitting screen which it has done for me before but this time they seem to be short of knowledge on this system. They are not charging me as they acknowledge they have wasted a lot of my time and theirs by faulty diagnosis of the issues.
I will have to get onto them again next week. Trouble is I have to leave the car with them.
pscocoa
« Reply #11 on: 19 August 2011, 20:03:36 »
Edwardmickey - you were much closer to the issue than you thought!!!
« Reply #12 on: 20 August 2011, 18:55:48 »
Go see Kevin Wood (or me, but think he's much closer), dealers really struggle with this sort of thing...
