Author Topic: ABS query  (Read 2438 times)
robbie j
  • Derby
ABS query
« on: 23 August 2011, 08:33:25 »
Robbie j here, a new member.  I've got a 2.5V6 which is a great car, but something strange happened whilst coming back from North Wales last Friday afternoon.
I was cruising along quite happily on the A55 when the ABS and Traction Control warning lights came on and the speedo dropped to zero.  The computer display also went awol.  After a while everything started working normally, and since then the fault comes and goes.  A pal who has an auto-electrical business tested it on his diagnostics TECH 1 and no fault was found and suggested I ought to get the fault diagnosed on a TECH 2, but the abs sensors seem OK.  It may be the abs pump.
Has anyone had this happen to their car?  When the cause is sorted, any suggestions where to get the part please?
    • E250 Est / Elroq
Re: ABS query
« Reply #1 on: 23 August 2011, 08:40:26 »
Hello & Welcome  :y
That is a classic ABS ECU faulire im afraid.
You can have them repaired - a bond wire breaks inside.
or you can buy a new one from one of the breakers on here - get the same years, engine size, and gearbox type.
If yuo go this route - place a wanted ad in the test zone and ill move it.
theres a fair few local mobile mechanics to the area it happened if its not a job you can tackle (see maint guide section, index in my sig, for whats involved) , but obviously dont know where you live.
robbie j
  • Derby
Re: ABS query
« Reply #2 on: 23 August 2011, 11:07:39 »
Hi Jimbob
Thank you for your help.  I'm in Derby, so don't know if that's any help!
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: ABS query
« Reply #3 on: 23 August 2011, 11:14:18 »
robbie j  - if you update your profile with your location, you will find it very beneficial in the future, as other Oofers on here will know where you are, and may even pop by to lend a hand when needed
Radio & Decoding Technician
www.dndservices.co.uk
rob in gib
  • Plymouth
    • Jaguar S type 3.0
Re: ABS query
« Reply #4 on: 23 August 2011, 12:08:39 »
I had the same symptoms when my alternator failed
although my car started sutting down one system at a time until dead
yours has come back to life but maybe worth checking the charging system
hth
Just chilling in the sun. I wish back in the rain like everybody else
Re: ABS query
« Reply #5 on: 23 August 2011, 14:03:18 »
Classic abs ecu failure as Jimbob suggests I'm afraid.  May come and go for a while but will eventually fail - lights on, no sopeedo, no cruise, some power steering loss.  Only cure swap/replace/repair abs ecu  :(
robbie j
  • Derby
Re: ABS query
« Reply #6 on: 23 August 2011, 14:25:54 »
Thanks for your help.  Much appreciated!
Re: ABS query
« Reply #7 on: 23 August 2011, 18:08:56 »
If you consider the repair option .. was around £130 with a 2 year warranty from BBA Reman about 4 years back .... was well pleased with their service.
twiglet
  • Norwich, Norfolk
Re: ABS query
« Reply #8 on: 23 August 2011, 22:59:04 »
Or PM Albs. He's breaking a car with the same engine and gearbox as yours. I think he still has the complete unit available.  :y
