C/L module swap
Started by RobG, 26 August 2011, 18:07:48
If you replace the C/L module with one with same part number is there any coding/pairing needed :question
Doubt it. ;)
I dont actually know though. ::)
QuoteDoubt it. ;)
Pointless bloody answer innit ;D
QuoteDoubt it. ;)
Maybe Albs is joining the conservatives?  ;D
Has hell frozen over ? ;)
For the Central Locking or Alarm ECU, only coding is teh key fobs.
QuoteFor the Central Locking or Alarm ECU, only coding is teh key fobs.
member outside of the UK wants the C/L module and a couple of key fobs amongst other things. The fobs and module are from 2 different cars. Member says he needs the immob. code for the fobs, I thought he only needs the code for his own car to pair the fobs :-/
To program the ECU, he needs the PIN code (Immobilser on carpass) from that ECU.  Not from his ECU.
