philips bose ccrt 700 power drain
Started by rolex666, 27 August 2011, 14:11:59
rolex666
Hi again chaps,
I have had a power drain problem which turns out to be the radio. the auto-lec [ vauxhall trained ] tells me that these particular radios have been prone to this problem.
Has anyone had this problem and, other than sourcing another radio, is there a solution.
I_want_an_Omega
Actually, sourcing another radio might not be such a bad idea.
How quickly does it flatten the battery?
They aren't expensive, maybe £40 via one of the breakers or ebay and would either fix the problem or give you a spare unit.
I might even have a spare one if you are interested. Let me see if I have the code for it.
Thanks - Rob
rolex666
Hi Rob
From a good charge it flattens overnight, no power to even run the radio. If you have a bose one I would be interested.
