Author Topic: Electric window switch: from Vauxhall to Opel.  (Read 4735 times)
WinRAR
    • Opel Omega 3.2 V6
« on: 16 August 2011, 16:18:48 »
Hello.
I screwed it up when trying to clean my electric window switch and it now looks like it has been licked and bitten by a pack of wolves. I need a replacement and the original part is expensive.
I've seen a part in a fairly good condition, but it comes from a RHD Vauxhall and I need it to work in a LHD Omega. The part looks identical, but the EPC shows a different part number. Maybe that's only due to the parts being for Vauxhall and Opel.
This is the piece I am eyeing:
Should I go for it? Will it work in my Opel?  ::)
« Last Edit: 16 August 2011, 16:19:52 by WinRAR »
WinRAR
    • Opel Omega 3.2 V6
Re: Electric window switch: from Vauxhall to Opel.
« Reply #1 on: 16 August 2011, 16:55:01 »
OK. It's the same. Any offers?  :P
twiglet
  • Norwich, Norfolk
« Reply #2 on: 17 August 2011, 10:21:56 »
PM sent.  :y
WinRAR
    • Opel Omega 3.2 V6
« Reply #3 on: 17 August 2011, 14:45:06 »
PM sent.  :y
Replied  :y
WinRAR
    • Opel Omega 3.2 V6
« Reply #4 on: 24 August 2011, 14:30:38 »
Hi all.
I opened this thread asking about the compatibility of electric window switches across Vauxhall and Opel cars.
Twiglet (thanks  :y) sent me the part and I've tested it today. Result of the test: it works, but it isn't fully compatible.
Plugs and holes fit perfectly, every button and switch is working, but... driver's switch raises and lowers passenger's window and viceversa. This only affects the front part of the car. The rear windows work as in the switch (i.e. right is right and left is left).
I didn't test the mirror adjustment switch, but it is probably switched as well.
I have a working LHD switch. There is a circuit in it which receives the driver's input. Switching this board will restore the LHD right and left behavior or is it a wiring issue?
Best regards.
« Last Edit: 24 August 2011, 14:31:39 by WinRAR »
« Reply #5 on: 24 August 2011, 15:19:08 »
..... but... driver's switch raises and lowers passenger's window and viceversa.  ....
Oh dear!  :-?
I'm sure you'll sort it or learn to live with it.  ;) :y
WinRAR
    • Opel Omega 3.2 V6
« Reply #6 on: 24 August 2011, 15:23:37 »
Oh dear!  :-?
Well, TIS says different wiring for LHD and RHD, so I'll live with it.
« Reply #7 on: 24 August 2011, 15:32:13 »
Oh dear!  :-?
I wonder if you could remove the relevent pins/sockets from the car's loom & swap them over  :-/ :-/
WinRAR
    • Opel Omega 3.2 V6
« Reply #8 on: 24 August 2011, 15:38:58 »
Oh dear!  :-?
I'd rather swap stuff from the switch itself than from the car's loom. I'd try to swap the top plastic cover, which is what is ugly on mine, but if I feel the slightest smell of fail, I'll leave it as it is. Not worth ruining a second working switch.
Either that or a new switch (€130  :'()
« Reply #9 on: 24 August 2011, 15:41:14 »
Oh dear!  :-?
Easy to do, two plastic tags each side, just depress, remove, replace, job done :y
WinRAR
    • Opel Omega 3.2 V6
« Reply #10 on: 24 August 2011, 15:45:41 »
Cool. That cover includes the buttons as well?
mathewst
  • Split, Croatia
    • v40
« Reply #11 on: 01 September 2011, 00:23:05 »
I also had this issue.
Broke mine and bought one from the UK, mine is Opel.
And front is different in Vauxhall. Front windows work oppositely now but the rear ones are ok.
Thought of rewiring  it but never had the time to do it
WinRAR
    • Opel Omega 3.2 V6
« Reply #12 on: 01 September 2011, 13:43:20 »
Finally I've switched the plastic cover and kept mi original LHD electrics and wiring. LHD and RHD electric windows switches are identical except for the wiring.
Thanks to twiglet, who sold and sent me the part at a fantastic price  :y
twiglet
  • Norwich, Norfolk
« Reply #13 on: 01 September 2011, 23:39:43 »
Glad I could be of help mate, and it's a good result in the end.  :y
