Author Topic: ripspeed DV720 not turn off?  (Read 4367 times)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« on: 17 September 2011, 03:21:34 »
dose any one know why the unit will not turn off,,, just says bye bye. and stays on ever thing eles is ok blinks for mo as going to turn off then comes back on and dose 2beeps???? thanks if any one know? works good apart from that...
Solar charger fitted.
If not Broke dont fix it..
I_want_an_Omega
Re: ripspeed DV720 not turn off?
« Reply #1 on: 17 September 2011, 07:57:04 »
Is this for the Omega Rusty?
Won't it cover up all the switches when it's out?
Isn't there something about Vauxhall swapping live and switched power over, could that have something to do with it?
Has it got a remote power on facility? If so then I'd look there first.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 17 September 2011, 08:45:29 »
You maybe better posting this thread in the Electrical Section mate.
Daz :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #3 on: 17 September 2011, 18:08:16 »
check ignition switch wiring the red and yellow wires on the radio end itll be in the head units insructions about reversing them if its not ill find you a Youtube vid you ca watch that explains it
freecall666
« Reply #4 on: 17 September 2011, 18:55:40 »
its been working in car for year with no problems. just wondering if and were the micro switch is, it maybe that. failing that get another board off bay.. nothing is burnt out on board, and thats the only problem with it only noticed it when went out and battery flat only had 6volts left in battery.
r1
  • nottingham
« Reply #5 on: 17 September 2011, 20:31:09 »
cant you just take the face off?
    • E250 Est / Elroq
« Reply #6 on: 17 September 2011, 20:36:30 »
[movedhere] General Car Chat [move by] Jimbob.
freecall666
« Reply #7 on: 18 September 2011, 05:17:21 »
dont know what you mean fixed front.. think its says some were that pieoner make the boards for them but dont know model name is.
freecall666
« Reply #8 on: 18 September 2011, 11:39:30 »
its ok just won one off bay under £40 with out audio out put problem so just going to swap audio chip with mine so should be fixed soon.. :y
I_want_an_Omega
« Reply #9 on: 18 September 2011, 16:45:16 »
Wont the chip be soldered in place?
freecall666
« Reply #10 on: 18 September 2011, 19:35:02 »
yeah but can remove it, easy job to remove. its not a micro chip, plus the one got may not even be the chip may just be the fuse for the amp on  the board there is 2 fuses for the amp on board.
    • 530D M Sport, 330i Coupe
« Reply #11 on: 18 September 2011, 19:45:01 »
Might be able to fix the power problem on the first one, I imagine the unit has got damp and the contacts on the microswitch for the screen closed position are rusty.
freecall666
« Reply #12 on: 18 September 2011, 20:25:57 »
no switch is fine, and screen is fine. somthing has crossed over so cotinous volts and ignition and shutdown are all stuck on. and damp shield is fine....... had unit down to bare bones just board and front pannel. then just board and fan still on so still power being on.
« Last Edit: 18 September 2011, 20:28:27 by freecall666 »
freecall666
« Reply #13 on: 20 September 2011, 18:19:05 »
right some good news and some bad news just found what is wrong just had friend e-mail me the board diagram and it would be a single chip that dose the lot. chip numberTDA7388. not only dose the sound dose standby- mute- sound- sound quality low. and some other stuff. so if you have this model with a fault as mentioned above then there is the bad boy. so will have 2 players soon as just got parts for both for £18-p&p so if want one after give me pm.. :y
« Reply #14 on: 21 September 2011, 10:54:24 »
The TDA7388 is just an audio power amplifier and nothing more. Can't see how it would prevent the head unit from powering down so I wouldn't be too hasty in ordering one, TBH. :-/
