Author Topic: hole in gearbox..  (Read 1143 times)
bertiecbx550
hole in gearbox..
« on: 25 February 2008, 13:37:01 »
ok i`ve got a problem something has punched a hole through the bell housing and made a hole twice the size of a 50p now there does not look like any damage to the clutch i can get all gears smoothly and the car pulls no different i`m just worried about the hole and what i should do next..2 questions i need answering are iz the 16v`s gearbox and housing the same as the 8v`s or can patch the hole with sumat i.e. weld a plate over to stop any water or debris from the road getting in??? any help in answering these questions would be great lads an lasses cheers..
Re: hole in gearbox..
« Reply #1 on: 25 February 2008, 14:44:19 »
Depending where it is.....I would be tempted to pop rivet a plate over it with some sealent around the edge to keep water out....
bertiecbx550
« Reply #2 on: 25 February 2008, 15:30:36 »
ok i will try that..cheers :)
