AR25 Gearbox applications
Started by twiglet, 24 September 2011, 17:15:10
twiglet
Will an AR25 gearbox from a 2003 2.6 petrol bolt straight into a 1999 2.5 diesel?
TIA  :y
I asked this question a couple of weeks ago (probably regarding the same person your enquiring for) iirc the answer was yes, but theres a thread here somehwere about it. ;)
Shackeng1
IIRC, you will have to swap the torque converter housing from your TD onto the AR25 before fitting to the TD. :y :y :y HTH
From he who was formerly known as Shackeng, but now denied access by the new regime. GRRRRR!
henryd
Quote from: Shackeng1 on 24 September 2011, 18:29:45
I thought the bellhousing was different on the TD.
Ref your problem logging on you have to use your user name to log in now,not your forum name,HTH :y
other rides
