Author Topic: LPG ready to go  (Read 3174 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
LPG ready to go
« on: 24 September 2011, 22:15:30 »
I spent my time going through it today finishing off what was left after Sunday's late night session with KW  :-*
So its all ready.  The tank is wired and connected, the front end is in, the loom is in and the fuel guqge is in.  All that is missing is the 20a fuse sat in the lounge.  I had to get a laptop working before I could connect it al but I must admit I am a little anxious about switching it on.  Will it blow up in a ball of flames, have the bits I've done upto scratch, is there anything I have forgotten?  These are all going through my mind tight now...... Has anyone else felt like this when doing their first lpg conversion?
Ken T
  • Stockport
Re: LPG ready to go
« Reply #1 on: 24 September 2011, 22:51:52 »
There should be no problem if KW was involved  :y.
However, if you are worried, how about this: Does the car still start on petrol ?. If so your injector wiring is OK, and there are no obvious shorts. Fit the fuse does it blow immediately ?. If not your LPG ECU wiring is probably OK. Go put in a liter of gas, any hissing sounds ?. You can go back to base and paint gas joints with Fairy Liquid to check for leaks if worried.
Its another fuel system, like petrol. Provided no leaks, which are a bit more severe than petrol, you can't see small leaks, then it should work. Provided your work is to a good standard, there should be no electrical probs so go for it, press that button, and .........
Dial 999 if really bad  ;D
Cheers Ken
PS best of luck, I am currently paying over £75 every 3 days  :'( :'( :'( :'(
Re: LPG ready to go
« Reply #2 on: 24 September 2011, 23:23:54 »
If you feel that way about it, Double check everything. Thoroughly. Is it all tight. All connected correctly. Etc etc. Get your fine tooth comb out.
Re: LPG ready to go
« Reply #3 on: 25 September 2011, 00:07:57 »
Cheers Ken
And run..... :D :D
symes
  • oxford
    • R reg 940 volvo
Re: LPG ready to go
« Reply #4 on: 25 September 2011, 00:15:11 »
or like me had someone questioning my set up and showed me their set up which had clips loose on injector block and smelt gas!!!!! PS mine was done by a pro not by me. Hope all goes well-should do its pretty much common sense really
Re: LPG ready to go
« Reply #5 on: 25 September 2011, 04:28:14 »
Man up wet pants! :D :D :D
But in all seriousness... Just give it a check through and go for it! Getting the calibration and mapping right is a bit of a faff with the new reducer so you may want to try and get someone to lend a hand :-\ What size did you drill the injectors to?
Oh... And if it makes you feel any better, I always feel a little nervous with every one I've done ;)
(Until I remember, it's not my rather car! ;D ;D
Re: LPG ready to go
« Reply #6 on: 25 September 2011, 04:44:05 »
 ;D not my car either!  ;D
Gaffers
Re: LPG ready to go
« Reply #7 on: 25 September 2011, 07:31:15 »
yer, keep your ratherdistance with that bag o gravel ;D
Re: LPG ready to go
« Reply #8 on: 25 September 2011, 08:34:41 »
I knew there was something I'd forgotten last time I changed the coil pack ;)
hopefully my mpg should improve a luttle
Re: LPG ready to go
« Reply #9 on: 25 September 2011, 08:52:18 »
if Paul or KW was involved then it will run fine! Mine ran sweet as a nut from first turn of the key  :)
Gaffers
Re: LPG ready to go
« Reply #10 on: 25 September 2011, 09:16:05 »
I have no worries about the bits that they and Chris did.  I made all the gas connections and I am worried about having them tight enough.  So much so I stripped an adaptor on the tank.  I guess I'll just have to go for it (with my fire extinguisher sat nearby ;D)
Re: LPG ready to go
« Reply #11 on: 26 September 2011, 09:54:45 »
Sorry I didn't return your calls this weekend.  :-[
Was out to dinner on Friday night and my phone's been on silent ever since.  ::)
How's the LPG? I can pop round one evening this week if it needs a tweak.
Gaffers
Re: LPG ready to go
« Reply #12 on: 26 September 2011, 17:59:25 »
I thought you may be busy given Tue occasion ::)
It's running quite well, just need to finish mapping.  I think I have a small leak in the engine bay though.  Out with the soapy water tonight
Gaffers
Re: LPG ready to go
« Reply #13 on: 26 September 2011, 23:04:49 »
Have been working on mapping today and it seems a little sluggish when booting it on LPG.  On petrol it's fine, just not on gas.
Re: LPG ready to go
« Reply #14 on: 26 September 2011, 23:06:32 »
Are the lambda sensors staying solidly "rich" when booting it?
Is the vapour pressure dropping significantly?
