Author Topic: Catera starts.then shuts off within seconds  (Read 3525 times)
AjOmega
  • Cali
« on: 25 September 2011, 20:58:13 »
My catera wont stay started it shuts right off everytime I try
To start it been sittin for 3 months. I changed the ignition lock cylinder and
The ignition switch. I was wondering could it be the fuel filter
Re: Catera starts.then shuts off within seconds
« Reply #1 on: 25 September 2011, 21:00:51 »
Have you swapped your immobiliser chip over from the old key? Try holding the old key next to the cylinder and starting it ;)
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #2 on: 25 September 2011, 21:51:20 »
It's worth doing to eliminate it, mine was doing something similar a while back, It's a fairly easy job  :y
jonnycool
« Reply #3 on: 25 September 2011, 21:52:32 »
....the fuel filter I mean  :-[
« Reply #4 on: 25 September 2011, 22:05:56 »
Typical immobiliser symptoms ;) I'd put my 1p on the op not swapping the chip over when he fitted the new barrel ;)
AjOmega
  • Cali
« Reply #5 on: 25 September 2011, 22:08:58 »
The new key I have it has a chip in it too and I held the other key
Next to the cylinder and still the same thing.And the new key and cylinder
Came with a black thing around it what is that for some type of sensor
AjOmega
  • Cali
« Reply #6 on: 25 September 2011, 22:10:44 »
Im sorry but whats 1p and op
« Reply #7 on: 25 September 2011, 22:14:43 »
1p = a penny
op = original poster ;)
So. You swapped the transponder ring over too?
I would suggest refitting your transponder ring (the black ring) and moving the chip from the old key to the new one :y ISTR that the chip, transponder ring and immobiliser ECU are all linked :-\
AjOmega
  • Cali
« Reply #8 on: 25 September 2011, 22:21:03 »
I havent exactly changed the ring over yet or the chips ???
« Reply #9 on: 25 September 2011, 22:29:13 »
So you still have the ring that was fitted to the car fitted? If so, try getting the little chip from the old key next to it
AjOmega
  • Cali
« Reply #10 on: 25 September 2011, 22:42:29 »
I tried that and it still didn't work and I tried the new 1 and that didnt work.
I forgot to mention the car been sitting since may could it have
Bad fuel
« Reply #11 on: 25 September 2011, 23:26:33 »
If the car starts and if rev'd immediately stalls try unplugging the MAF sensor.  If its OK then you need a new MAF  ;)
AjOmega
  • Cali
« Reply #12 on: 26 September 2011, 00:14:47 »
Were is the maf sensor located
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #13 on: 26 September 2011, 00:34:48 »
bad petrol ?
AjOmega
  • Cali
« Reply #14 on: 26 September 2011, 00:43:24 »
If its bad gas do I add new gas to it
