Author Topic: 2.6 spark plugs  (Read 893 times)
martin42
2.6 spark plugs
« on: 26 September 2011, 20:05:10 »
im in the process of doing cam cover gaskets,oil has been leaking into plug holes,removed as much oil as i can and removed plugs,im on a very tight budget at the moment and cant really afford the £40+ for the plugs,is there an alternative that i can use in stead of the 4 prong plugs,also does anybody have a spare rubber seal for the passenger side bank coil pack as that is missing,thanks for the help.
Also the how to guide came in very handy aswell, :y
Re: 2.6 spark plugs
« Reply #1 on: 26 September 2011, 20:12:38 »
..... im on a very tight budget at the moment and cant really afford the £40+ for the plugs,is there an alternative that i can use in stead of the 4 prong plugs,
which is where it's cheaper in the long run to pay to be a member of the Autobahnstormrs club for around £20 per year. Plugs would then cost you around £2.50 each on Vauxhall's Trade Club.
there's bit more to sorting an oil leak than a 'rubber seal'  ;) ;) ;) If you buy cheap pattern gaskets you'll soon be doing them again ................. and do the breathers while you're at it.  :y :y
martin42
Re: 2.6 spark plugs
« Reply #2 on: 26 September 2011, 20:15:09 »
im going to be doing breathers aswell,looks like the gaskets have never been touched during the life of the car,might have to see about joining the trade club then  ;)
Re: 2.6 spark plugs
« Reply #3 on: 26 September 2011, 20:19:06 »
It is worth it, even just 10W-40 oil Trade Club which pays for the ABS membership the first time you buy 4 lots of 5 litres for the price of 3  :y :y
