Author Topic: Wheel bearing OEM  (Read 3363 times)
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
Wheel bearing OEM
« on: 28 September 2011, 16:20:45 »
Does anybody know who is the OEM for Omega front wheel bearings?
Given that Vx charge well into 3 figures even with TC, I would be keen to source elsewhere if the quality is similar.
I can get Contitech or Febi cheap - is either any good?
TIA
I feel like a military academy. Bits of me keep passing out.
Re: Wheel bearing OEM
« Reply #1 on: 28 September 2011, 17:56:40 »
Have a search for Entwood's experiences with pattern wheel bearings from France.  ??? ???
It could be cheaper in the end to bite the bullet & pay Vx's prices.  ;)
« Reply #2 on: 28 September 2011, 19:02:28 »
Conti tech barings in hub have been the the recommended part afaik, but it has transpired that they have an amount of play even when new.
Quite where we go from there I'm not sure.
 One of my new contitech barings has Play that equals the play on the other wheel. So I didn't bother replacing it.
If we have a beter source of barings that don't cost the earth I'm all ears. :(
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #3 on: 28 September 2011, 22:20:53 »
TIA
had to replace a febi on mine today( with an old one that has less play), failed in less than 4 months & sod all miles.
« Reply #4 on: 28 September 2011, 22:28:30 »
Saga  about mine here ...  http://www.omegaowners.com/forum/index.php?topic=85316.0
New VX one worked out at £122 inc VAT
HTH
Osprey
  • Redhill, Surrey
« Reply #5 on: 29 September 2011, 00:04:43 »
Ho hum - looks like I'd better bite the bullet.
Thanks for the advice  :y
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #6 on: 29 September 2011, 19:26:51 »
TIA
I believe SKF supplied the bearings to factory assembly line, IIRC was told so by people from SKF
Osprey
  • Redhill, Surrey
« Reply #7 on: 30 September 2011, 14:58:03 »
I have just collected a genuine bearing unit from Stevens Vauxhall Crawley.  The bearings and casting are marked KOYO Japan, with the bearings being DACF1018L.
Of course this is not to say that KOYO supplied the original manufacturing plant - just that Vx are currently using them for replacements.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #8 on: 01 October 2011, 14:29:59 »
And I may have wrong information... Just thinkin that it might have been the rears that were SKF, on estates...  ???
Osprey
  • Redhill, Surrey
« Reply #9 on: 01 October 2011, 19:20:40 »
Changed the NSF wheel bearing today.  The old one was also Koyo - could be original after 120K, who knows.
FWIW I used the standard issue Halfrauds 60 to 300Nm torque wrench.  It actually has graduations up to 310Nm then has further adjustment into no-man’s land for the equivalent of about another couple of dozen Nm.  So it is easy to judge where 320Nm would be.  OK, so Mr Halford won’t guarantee that it is spot on but I am confident that it is pretty darn close, and certainly 300Nm plus a bit.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #10 on: 01 October 2011, 19:32:46 »
320 Nm is pretty darn tight, as tight as you can get with bare hands and some regular tools. It is assumable you can not overtighten this kind of a bearing  :y And, relevancy between nut being 300 Nm or 350 Nm is... well, it's  :D tight anyway.
« Reply #11 on: 02 October 2011, 08:27:08 »
So was this a genuine vx wheel baring in hub fitted? And was there any play? Guessing vx and no play?
Osprey
  • Redhill, Surrey
« Reply #12 on: 02 October 2011, 17:50:56 »
Yep, genuine Vx, manufactured by Koyo, no play that I can feel.  Although the play only disappeared as the torque was getting quite high - as you would expect.
« Reply #13 on: 02 October 2011, 19:14:40 »
ok, thanks for coming back.
Interesting how much they squeeze up in the later stages of tightening. Does point to I slight error in machining inner race surfaces on the dodgy ones I suppose...
« Reply #14 on: 02 October 2011, 19:16:36 »
Page created in 0.018 seconds with 14 queries.
