Author Topic: powersounder problem  (Read 2376 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« on: 02 October 2011, 08:49:02 »
Every time I go through a car wash the power sounder goes off then goes off randomly for about 30 mins any ideas thanks.
Re: powersounder problem
« Reply #1 on: 02 October 2011, 09:03:50 »
Most likely knacked, as the water falling on it (there is a drain hole right above it) is probably final straw...
    • E250 Est / Elroq
« Reply #2 on: 02 October 2011, 09:04:29 »
take it out and get rid!  they can and do set themselves on fire!  take it out, today!
see maint guides if unsure.
plym ian
  • Plymouth, Devon
« Reply #3 on: 02 October 2011, 12:00:24 »
cheers lads will do it tomorrow. dose it affect the alarm at all?
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
« Reply #4 on: 02 October 2011, 12:32:22 »
There is a car horn that sits beside your Powersounder. You'll see it when you lift the scuttle to get at the Powersounder. That will sound if you have an activation.
« Reply #5 on: 02 October 2011, 13:13:10 »
The purpose of the powersounder is to sound if the alarm goes off, but the battery is discharged or disconnected.
Tbh, your insurance co. probably wouldnt be best pleased if they knew it was missing,although they also wouldnt be pleased if they knew your car caught fire because of it when you knew it was faulty, so your call whether or not you replace it. If you do replace it dont consider buying a used one. Iirc they are around £70 from VX.
Personally, I have removed it from every Omega Ive had, opened them up, removed batteries and chucked the whole lot in the bin.
« Reply #6 on: 02 October 2011, 13:14:52 »
By battery, I mean the car battery.The powersounder has its own internal batteries which allow it to sound in the absence of a charged battery on the car. :y
Bring back the edit button. ::) ;D
JIFFY
  • SOUTH WALES
  • "If it aint broke dont fix it"
    • 2001 2.2 cdx
« Reply #7 on: 02 October 2011, 23:43:16 »
as all the other ppl have said,ive had 4 omegas now,the first one the alarm was intermittantly goin off,
after 2 days it caught fire,i allways remove mine now regardless of condition,
easy to remove and tape up the terminal block,
hope this helps,
