Author Topic: Auto Gear Change  (Read 1587 times)
cameraman1954
Auto Gear Change
« on: 04 October 2011, 01:29:24 »
Hi Guys,
Can anyone help, the warning light on dash showing car with spanner is on permanent.
When D is selected car moves of in 3rd or 4th gear, can't select sports mode or winter driving mode, using petrol as thought its going out of fashion, seems to be running hotter than normal and at speed is not changing into top gear.
Also how do you check Auto Box Oil Level.
Re: Auto Gear Change
« Reply #1 on: 04 October 2011, 01:36:59 »
Need a decent code reader to find the fault. Cam sensor has been known to cause havoc with the autobox (code 0340). Auto fluid level check http://www.omegaowners.com/forum/index.php?topic=90508.0
« Reply #2 on: 04 October 2011, 01:39:16 »
Selector switch is another possibility for box going into "limp mode". But as said, get codes read first.
Guide for cleaning selector switch here http://www.omegaowners.com/forum/index.php?topic=90673.0
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #3 on: 04 October 2011, 06:56:43 »
You need to get the codes read first, but it does sound like the classic cam sensor fault common on 2.2's.
I like red cars
KJO
  • Cork
« Reply #4 on: 05 October 2011, 20:45:28 »
Had the same problem earlier this year. Don't run the car too long with the auto box in limp mode as it will knacker it. Probabley the selector switch but do as advised and have it checked out by having the fault codes read, I left it and ended up having to replace the box at a cost of £650. :'(
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
« Reply #5 on: 05 October 2011, 20:53:44 »
You can shift gear manually but it won't go into top. Selector switches usually fail steadily rather than all at once.
My Astra has similar fault. I've used it for two years like that. You get fed up of shifting it and the fuel consumption is worse than running the 2.5 miggy.  :'(
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Dodge
  • Wrexham
    • 2.2 CD auto lpg/petrol
« Reply #6 on: 08 October 2011, 22:54:03 »
selector switch is the most common fault with the 2.2 auto. Get along to a decent auto specialist and get the codes checked
« Reply #7 on: 08 October 2011, 23:06:12 »
Where abouts are you? Yes I know Co Durham, for the wise crackers :P, but Co Durham is a big place... :y :y
David Oliver Auto Electrical in Ferryhill have all the gear and do not charge you ott....... or I can read your codes..
