Author Topic: Re: cooling  (Read 7878 times)
bored bigyin54
  • south wales
    • black beast
Re: cooling
« on: 04 October 2011, 11:31:50 »
the hbv is done but still got a leak from the back off engine
Re: cooling
« Reply #1 on: 04 October 2011, 11:55:11 »
its worth checking all the coolant pipes, even a tiny split can pi$$ water everywhere. Common one is the one of the coolant bridge  :y
Re: cooling
« Reply #2 on: 04 October 2011, 12:01:12 »
Oil cooler was changed a few months ago.Im wondering if the mechanic has used the wrong sealant or reused dowty washers or similar. :-\
Need a good torch and possibly a mirror, then take some time and try to see where its coming from.After that its plenum off,and if source cant be seen, the cooling system will need pressurising to see the leak. Pressurising might just be a matter of someone blowing hard into the neck of the header tank, while someone else looks for water spurting out. ;)
bored bigyin54
  • south wales
    • black beast
Re: cooling
« Reply #3 on: 04 October 2011, 12:04:47 »
the selant was from vx
Re: cooling
« Reply #4 on: 04 October 2011, 12:06:39 »
what about dowty washers?
You going to have to take off the plenum and injection manifold, inspect all around the oil cooler and coolant bridge for signs of a leak
bored bigyin54
  • south wales
    • black beast
Re: cooling
« Reply #5 on: 04 October 2011, 12:07:59 »
i have never taken the pleneum off
Re: cooling
« Reply #6 on: 04 October 2011, 12:13:05 »
Well, if you want to find the source of your coolant loss, you will have to. Otherwise i will have to be taken to a garage  :(
Details here:
http://www.omegaowners.com/forum/index.php?topic=90657.0
http://www.omegaowners.com/forum/index.php?topic=90545.0
Re: cooling
« Reply #7 on: 04 October 2011, 12:25:37 »
Its not difficult to do Ralf,as long as you have a set of torx sockets ? Just follow the guide,be methodical,take your time, and stuff kitchen roll or similar in the ports until your ready to put the plenum back on.If you drop a bolt or similar down one of the ports it could be a head off job.
bored bigyin54
  • south wales
    • black beast
Re: cooling
« Reply #8 on: 04 October 2011, 15:03:24 »
well i cut my finger anyway and the car is going back to the guy who done the oilcooler
bored bigyin54
  • south wales
    • black beast
Re: cooling
« Reply #9 on: 05 October 2011, 07:50:59 »
dowdy washers from vx as well
Re: cooling
« Reply #10 on: 05 October 2011, 11:39:02 »
Start with the simpler things - a leak from a hose.May well need to remove plenum and inlet manifold to see it though.
bored bigyin54
  • south wales
    • black beast
Re: cooling
« Reply #11 on: 05 October 2011, 12:58:55 »
its going back to the guy who done oilcooler
bored bigyin54
  • south wales
    • black beast
Re: cooling
« Reply #12 on: 06 October 2011, 18:12:27 »
just drove car down to the guy who done oilcooler got there at had no water dripping down weird or what
Re: cooling
« Reply #13 on: 06 October 2011, 18:14:58 »
HBV's have a tendency to only leak when in a certain position, and that position is dictated by a combination of the ambient temperature, the actual temperature inside the car, and  the selected temperature inside the car.
Might be worth lying with the selected temperature whilst the engine is running .. you may find the leak that way.
bored bigyin54
  • south wales
    • black beast
Re: cooling
« Reply #14 on: 06 October 2011, 18:19:18 »
done that after changing hbv valve was dry but still water dripping until today when i drove it there was none dripping
Pages: [1] 2 3 4  All   Go Up
