Author Topic: settings for 4 wheel alignment???  (Read 1267 times)
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« on: 05 October 2011, 11:59:13 »
i'm vaguely aware that there are some non std specs for alignment , toe in and camber,  for older miggys.
my mv6 has 132k on her, and is having all new shocks, wishbones, drop links, AR bushes, and tyres fitted today....  the garage does 4 wheel laser alignment (a premium blackcircles fitting centre)
so...  what should i ask them to do ???
(£50 extra for 4 wheel laser alignment while doing the rest of the work  seems cheap)
MaxV6
  • Oxford UK
Re: settings for 4 wheel alignment???
« Reply #1 on: 05 October 2011, 11:59:50 »
(2001 3.2 facelift MV6 estate Y plate)
« Reply #2 on: 05 October 2011, 12:02:15 »
Do you mean 4 wheel alignment (waste of time and money) or the full geometry setup as per WIM? If the latter (and they are approved by WIM for Geometry) then Tony will make sure they have the right settings :y
« Reply #3 on: 05 October 2011, 12:02:51 »
take it to WIM in Chesham Max, its more than worth the extra spend in fuel  :y
« Reply #4 on: 05 October 2011, 12:05:40 »
Not that far from Oxford anyway. 40 miles tops ?
MaxV6
  • Oxford UK
« Reply #5 on: 05 October 2011, 12:30:08 »
yeah, that was always my long term plan.....
but since it's in the garage, having the work done  (right this minute) i thought it worth asking.....   before i go and wear bits off my brand new tyres....   ....
man, the inner edges of my old tyres were scary.....
« Reply #6 on: 05 October 2011, 12:33:36 »
Personally, I would drive it straight out of the garage after having new shocks ect done and new boots, and take it straight down there.  :y
« Reply #7 on: 05 October 2011, 19:09:36 »
I concur, 4 wheel laser alignment will do sod all to protect your new shiny tyres. WIM it, given your location :y
« Reply #8 on: 05 October 2011, 21:46:24 »
-1.10 camber for stock suspension
-0.10 toe
But take it to Wim. For full geometric set up. Caster camber toe on the front. Toe affecting camber on the rear.
