Author Topic: Paperclip test - Code 12 ??  (Read 1319 times)
ScaniaV8
  • Luton, Bedfordshire
« on: 06 October 2011, 09:16:29 »
Yesterday, I experienced an intermitent EMC light flashing occasionally when accelerating quickly. (auto/ 2.5 petrol)
The EMC light did not stay on and acceleration seemed to clear itself quite quickly. When I returned home, I did the paperclip test with the engine running and logged codes 12 (3 times) and 19 (3 times).
I assume code is pointing to the crankshaft sensor being the source problem but I do not know what problem is code 12 ??
Could anyone please explain?.
Many thanks
Re: Paperclip test - Code 12 ??
« Reply #1 on: 06 October 2011, 09:28:37 »
12 is for the start of the code sequence and nothing to worry about ;)
ScaniaV8
« Reply #2 on: 06 October 2011, 09:31:40 »
Thanks Pete for prompt reply, much appreciated.
Am I correct in assuming code 19 will be the Crankshaft sensor needing replaced?
cheers
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #3 on: 06 October 2011, 09:39:45 »
yes 19 is c/shaft sensor. :y
« Reply #4 on: 06 October 2011, 09:45:04 »
Buy a genuine one from Vauxhall and not a cheap pattern part one ;)
