Author Topic: done cam gaskets but  (Read 1387 times)
martin42
« on: 06 October 2011, 18:37:26 »
now it the mv6 is missfiring,engine light comes on,ive checked all connectors,was running fine when i started it up after doing cam gaskets,got petrol went home,went back out and started fine,pulled away at a junction and then the miss firing started,any ideas please as i was ment to be going away at the weekend  :'(
Re: done cam gaskets but
« Reply #1 on: 06 October 2011, 18:43:12 »
Had cam covers failed before? Had it been driven with oil in plugs? Its possible you've cooked the HT lead.
I'd do a paperclip/pedal test see which pot is miss-firing. Transfer HT leads, see if fault moves. If not could be DIS pack.
Did you use genuine gaskets?
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #2 on: 06 October 2011, 18:56:50 »
as tunnie says  :y plus check all plug leads firmly home and egr plug hasnt come adrift, i done exactly the same thing put everything back together started hr up and had a misfire and emissions light was on  :( wondered what the hell i had done or what was wrong now  :o took me ages but eventually noticed egr plug hanging down side of engine  :-[
« Reply #3 on: 06 October 2011, 19:03:19 »
Trapped sensor wire under the camcover ? :-\
martin42
« Reply #4 on: 06 October 2011, 19:10:35 »
Got a fault code off 300 going to put old plugs back in and see if that makes a difference
martin42
« Reply #5 on: 06 October 2011, 19:14:22 »
Sorry forgot to say its a 2.6
« Reply #6 on: 06 October 2011, 19:15:02 »
Random miss, and it must be a DBW, so would give individual cylinder codes as well...
martin42
« Reply #7 on: 06 October 2011, 19:18:04 »
Ok will go and check codes again  :y
martin42
« Reply #8 on: 06 October 2011, 19:27:53 »
Got 0303,going to check dis pack 2moro as too dark now
martin42
« Reply #9 on: 07 October 2011, 18:18:15 »
took both coil packs out and they are buggered :'(
need to source some cheap 1's if anybody knows where i can get them from  :y
