timing belt.
Started by sotmh, 07 October 2011, 00:36:13
sotmh
eh guys assistance needed please.
replaced exjisting belt timing belt on 2.0 but found tensioner not tightening and deflection is excessive.  Only done between 15k and 20k miles (will check).
Would belt need changing? and therefore tensioner ok.
I thought tensioner may be damaged.
what are your thoughts please people?
Was the water pump fitted correctly?
sotmh
I refitted myself.  First time done therefore will have a check.  Also how do I check water pump fitted correctly?
Darth Loo-knee
There is a "tab" on the water pump that needs to go into its position
