Author Topic: Accident and now tyre noise  (Read 1785 times)
fatbob
  • Costa Blanca, Spain
« on: 09 October 2011, 09:46:17 »
Hi guys
I had a bit of a bump and now the headlamp wobbles... LHD and it's the passenger side - it's ruined the aim.  Had an argument with a concrete verge in the road.  Quite a bit of damage - wishbone, shocker, hub... pics here.
It's been aligned, but now it feels as though a wheel is buckled even though it's been checked.
Any idea what else could cause this noise?
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: Accident and now tyre noise
« Reply #1 on: 09 October 2011, 10:14:59 »
has it had a full camber check ??? or just the tracking done ??? :-\
« Reply #2 on: 09 October 2011, 10:40:59 »
Subframe could well be distorted.  Hard to tell from pic, has the A post deformed - if so, thats probably written off.
  • Auckland
    • Mazda MPV
« Reply #3 on: 09 October 2011, 10:50:25 »
If the impact was hard enough to rip the balljoint off the end of the wishbone I would expect a buckled wheel was pretty much guaranteed  :-\
The impact on the tyre wall might also have caused delamination, there might be a bulge on the inside of the tyre causing vibration?
I would swap the wheel to the rear of the car and see if the vibration goes with it.
fatbob
« Reply #4 on: 09 October 2011, 11:13:15 »
Can any garage do that?? I'm in Spain and don't know any really good garages
« Reply #5 on: 09 October 2011, 11:37:25 »
no
    • 530D M Sport, 330i Coupe
« Reply #6 on: 09 October 2011, 11:37:56 »
Looking at the lowest point of the wheel it looks distorted to me. Would also imagine the vertical mount point for the wishbone is probably distorted as well
fatbob
« Reply #7 on: 09 October 2011, 13:33:46 »
Thanks for the advice guys...
The tyre was replaced and the wheel repaired (only cosmetic damage, I believe) and sprayed.
The front wheel was put on the back....
Does feel like a buckled wheel tho...
  • Auckland
    • Mazda MPV
« Reply #8 on: 09 October 2011, 13:52:27 »
Did the back wheel hit the same concrete lump?
fatbob
« Reply #9 on: 09 October 2011, 16:46:49 »
nah, just front corner
Agemo
  • Cleethorpes
  • Insignia
« Reply #10 on: 09 October 2011, 16:53:25 »
Please confirm that you had a new wishbone, the strut looks bent too, meaning it will be well out even on full adjustment. Try getting the car absolutely level, then measuring the amount of lean on the wheel. Compare with the other (good) side.
  • Auckland
    • Mazda MPV
« Reply #11 on: 12 October 2011, 21:14:30 »
Don't assume that rear wheel balance is unimportant. It is possible vibration from the rear of the car is shaking everything hard enough tat you feel it through the steering.
It is also possible that the shock of the impact dislodged or broke the headlamp adjuster on the passenger side  :-\
