Author Topic: auto box fault >?  (Read 1912 times)
pirate
  • westhumble surrey
    • steinmetz elit estate
auto box fault >?
« on: 09 October 2011, 21:49:17 »
drove up to lincs to see elderly mother friday sat morning got in started went to drive of no power pulled away very slow drove about 3 miles then cleared and back to normal had  auto box fault come up on screen when i turned off not done it since. thoughts low oil or electrical gremlin.
millwall
  • se london
  • no muff too tuff
    • accord type s
Re: auto box fault >?
« Reply #1 on: 09 October 2011, 21:53:08 »
i would of thought electrical gremlin to bring up the message  but no harm in checking oil level :y
Dodge
  • Wrexham
    • 2.2 CD auto lpg/petrol
« Reply #2 on: 09 October 2011, 21:53:36 »
get the codes checked but wouldn't be suprised if it was the EGR valve
« Reply #3 on: 09 October 2011, 21:54:04 »
Any codes in engine or gearbox?
Also, worth checking/replacing ATF
« Reply #4 on: 09 October 2011, 21:54:52 »
Really :o
Not know EGRs to throw gearbox codes on Omegas... :y
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #5 on: 09 October 2011, 21:58:01 »
im sure ive read somewhere cam sensor can cause box trouble  but then again i probably read it wrong
« Reply #6 on: 09 October 2011, 22:00:19 »
On the 4-pots, yes. :y OP doesn`t state what engine :-\
Dodge
  • Wrexham
« Reply #7 on: 09 October 2011, 22:22:47 »
Yes, the EGR valve can do this, so can the cam shaft position sensor.  Both can send the gear box into limp home mode. It forces you to get the codes checked.  Something that happened after it was realised that so many people will ignore a warning light if the car appears to be running ok, Quoted from a vauxhall master technician!
pirate
  • westhumble surrey
« Reply #8 on: 10 October 2011, 17:24:28 »
i will get the code checked should be in memory ? running fine for last 183 miles.
ps its a cammed 2.5 v6 steinmetz estate
