Author Topic: Idle Air Control valve?  (Read 3685 times)
« on: 12 October 2011, 15:18:45 »
From cold my car starts first turn of the key (battery permitting  ::)) with no need to touch the throttle. However, sometimes when hot I need to feather the throttle to start it, otherwise it's very reluctant to start, once started though its runs OK. Also, sometimes after a long spell on the motorway, it wants to tick over at more like 1000rpm/1200rpm, a quick blip of the throttle will sort it. At Newent this year when Kevin W was playing on the Tech II with the IAC valve it did something similar re the revs/tick over. The valve has been off a couple of times & flushed out with acetone, no crap in there really, no 3-in-1 though  :-\.
Any thoughts? A N Other IAC valve? Another clear out?
Re: Idle Air Control valve?
« Reply #1 on: 12 October 2011, 18:27:29 »
It really does need lubricating mate or there is a tendency for it to stick  ;)
« Reply #2 on: 12 October 2011, 18:40:00 »
If a bit of oil doesn't cure it, replace it :y
« Reply #3 on: 12 October 2011, 20:37:18 »
I suppose that's the obvious answer .....  ::) ::)
I'll take it out next week some time, back in work tomorrow for 5 days  :(
Thanks  :y :y
« Reply #4 on: 13 October 2011, 00:01:48 »
IIRC the idle air valve was doing odd things on actuator test, like the revs increasing while the valve was supposedly being closed. Makes me wonder if it's had it. :-\
bored bigyin54
  • south wales
    • black beast
« Reply #5 on: 13 October 2011, 00:08:29 »
i got a new one from vauxhall about 3 years ago for my old car it was a 2ltr cdxi about £120
« Reply #6 on: 13 October 2011, 16:16:56 »
..... Makes me wonder if it's had it. :-\
I'm inclined to agree, hence the thread, but it won't get a new one. A second hand maybe.  ::) I'll see what lub'ing does - if anything.  :y
« Reply #7 on: 13 October 2011, 16:17:31 »
It ain't getting a new one ......
alexw80
  • Bognor Regis
    • P reg Omega 2.0 CDX
« Reply #8 on: 14 October 2011, 07:51:37 »
Replaced mine with one from the scrappies for a tenner, sod paying £120 for new. Almost more than the car was worth lol
Pete Elite
  • Uxbridge, Middlesex
« Reply #9 on: 14 October 2011, 15:43:12 »
  Hi Andy,
              I'm sure I've got one you can have for the cost of postage :y.
          PM me if your interested.
               Pete :).
Debs.
« Reply #10 on: 28 October 2011, 21:13:03 »
Did you sort out the idle-problem, Andy? :-\
« Reply #11 on: 28 October 2011, 22:22:46 »
Not had chance to have a play - work is all or nothing. I've another IACV to try now though &, weather pending should get chance over the week end. I'll let you know. :y
« Reply #12 on: 29 October 2011, 10:42:16 »
if you have the ability to check live data, look at the maf as well :y
« Reply #13 on: 29 October 2011, 11:11:31 »
Not at home  :( but I know a Captn who can  ;D ;D
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #14 on: 30 October 2011, 08:26:05 »
Make sure the throttle butterflies are closing properly had the same problem. for some reason the butterflies were out of adjustment even though the had not been tampered with. Slight reajustment now tickover sits rock solid at just over 500 rpm
