Author Topic: A Huge Thanks  (Read 1861 times)
Re: A Huge Thanks
« Reply #15 on: 08 March 2008, 22:00:01 »
What work was done?
I need to talk nicely to Mark, I could do with someone who has a pressure bleeder for my clutch ::)
I've an easibleed here, but tbh you can pick them up for around a tenner on ebay, so probably cheaper than petrol/postage....
Will an easibleed bleed the Omega clutch effectively? Looks like that'll be the best option if so !
The clutch is probably best bled from the bottom bleeder, so get an easibleed and bodge it to push fluid into the bleed valve rather than into the reservoir.
That's my understanding too :y
I bled it last time with a pot, a pipe, and 2 of us pumping the clutch/closing the nipple respectively... I am wondering if maybe that wasn't effective enough.
Re: A Huge Thanks
« Reply #16 on: 10 March 2008, 08:48:24 »
Cheers Daz, good to have a catch up.
Mrs Jimbob was very proud of her biscuit arranging....was her 1st time, Mrs DTM has trained her well  ;D
Daz wanted some tech2ing and a check out..
Mrs Jimbob...
Steering Idler
Wheel Bearing
Replace Aftermarket corsa aerial  ;D
Fix some rattley doors
Clean some oily plugs :( best get that cam cover gasket ordered  :(
Throttle Body Clean
Bit of minor geometry..
Quite a few little jobs really!
Thanks again Mark, car drove beautifully home, never felt that good  :y
I dont half ache today.....but think that is more down to Sundays activities, those slides were mental  ;D
Re: A Huge Thanks
« Reply #17 on: 10 March 2008, 09:04:06 »
Good to see everybody.
Daz, we forgot to check the config codes on your dash etc........
