Author Topic: Injector question.  (Read 2120 times)
Injector question.
« on: 13 October 2011, 12:15:22 »
The brown plastic/bakalite ? washers/seals on the end of the injectors.Are they particularily important ? I have 5 of 6 missing.
Currently have a set of 3.2 injectors on the car (2.5) and the car spends most of its life running on LPG anyway.Would prefer to swap back to the original injectors if the missing bits arent going cause a problem. :-\ Are they replaceable ?  Tia.
Re: Injector question.
« Reply #1 on: 13 October 2011, 12:50:37 »
You might find the O rings get sucked off the end of the injectors and into the intake without them. :-\
« Reply #2 on: 13 October 2011, 12:59:27 »
Good point Kevin.Do you know if they are replaceable/available ? :-\
« Reply #3 on: 13 October 2011, 13:06:46 »
I'm sure they are but I wouldn't know where to look, TBH. :-\
« Reply #4 on: 13 October 2011, 13:15:37 »
Albs - I'd normally suggest trying one of the helpful breakers on this site ;D ;D ;D
Sure Twigs/Pinky/EP etc etc can sort you one if you're not expecting one in soon yourself :y
« Reply #5 on: 13 October 2011, 13:37:37 »
I have a perfectly good set on an engine which sits on my drive,but they are on a very sweet running low mileage engine.Dont want to start pulling bits off it. ;)
« Reply #6 on: 13 October 2011, 13:39:47 »
Will ask Twigs though.Hadnt thought to ask him to be honest,but Im sure he will help if he can.Hes a fine young gentleman,but dont tell him I said so. ;) ;D
twiglet
  • Norwich, Norfolk
« Reply #7 on: 13 October 2011, 14:44:30 »
I've got 2 sets of 2.6 injectors here so, assuming they are the same, I'm sure we can sort something out next week.  :y
I hope I'm not breaking any rules by mentioning this in the General Help section!  :-\ :P :-X
« Reply #8 on: 13 October 2011, 14:49:15 »
No idea if they are the same James.Hopefully someone else will know. :y
« Reply #9 on: 13 October 2011, 14:56:08 »
IIRC, 2.6/3.2 have different injectors and a higher fuel pressure than 2.5/3.0. The question is: does this matter? If they flow at roughly the same rate and have the same electrical characteristics probably not. Does anyone have the two part numbers so I can compare specs? (It's the Bosch number - 0280 xxx xxx)
« Reply #10 on: 13 October 2011, 15:01:24 »
Got 3.2 injectors complete with fpr etc on there at the moment.Car seems to take a bit longer to start from cold than I would expect,and I seem to use more petrol than I woud like.May not be connected though,planning on changing the plugs at the next service in a few weeks time,so that could improve the percieved problem. :-\
No idea on P/N btw,and if there is one on an injector,probablt too small for me to read. ;D
« Reply #11 on: 13 October 2011, 15:07:10 »
No idea on P/N btw,and if there is one on an injector,probably too small for me to read. ;D
.....or perhaps not. 2.5 injectors - blue - 0 280 155 712. Below that it has A  961.
On the FPR - 3.0Bar. 0 280 160 560.
« Reply #12 on: 13 October 2011, 15:11:21 »
Part No.Flow Lb/hFlow cc/minPSIBAR
0-280-155-71219.4203.943.53
« Reply #13 on: 13 October 2011, 15:12:35 »
Dont mean sh1t to me Kevin. :-[ ;D
« Reply #14 on: 13 October 2011, 16:02:50 »
It doesn't to me either, until we have the part number of the other injectors. ;)
Basically, it's flowing 203.9 cc/min at 3 BAR fuel pressure.
The 2.6/3.2 injectors work at 3.8 BAR IIRC, so the question is what is their flow rate at 3.8 BAR?
