Author Topic: ignition barrel  (Read 935 times)
aiden
  • middx
    • omega cdx estate
ignition barrel
« on: 13 October 2011, 13:15:12 »
hi,  are there any problems with changing ignition barrel. aiden
Re: ignition barrel
« Reply #1 on: 13 October 2011, 13:17:09 »
Not really, though the old ones are normally easily repaired TBH, so you can use same key in door :y
The immboliser ECU around the barrel is coded to the engine ECU (and the key transponders are coded to the immobiliser)...
Page created in 0.023 seconds with 16 queries.
