Author Topic: f/l estate locks  (Read 1232 times)
MV6Danny
  • Swindon, Wiltshire
  • Driving at the speed of light
    • 99 irmscher mv6 3l Manual
f/l estate locks
« on: 13 October 2011, 20:38:34 »
Hi guys i am after a set of locks for my pf/l sallon and found someone with a set of locks from a f/l estate.
Does anyone know if these will fit on to a pf/l saloon? with or without modifications
Thanks Danny :y
Back in the MV6 again now
Re: f/l estate locks
« Reply #1 on: 13 October 2011, 21:07:47 »
Ignition & driver's door will be the same, no idea re the boot & tailgate lock though.
What's the reason for swapping locks? Don't forget the chip needs to stay with the respective car.  :y :y
MV6Danny
« Reply #2 on: 14 October 2011, 07:43:30 »
i am changing them due to not having a key for the boot. the central locking failed the other week and i had to climb throught the back seats to open the boot. turns out one of the wires was broken. all fixed now but would like to have a key just incase it fails again. :y
« Reply #3 on: 14 October 2011, 08:51:32 »
It's probably easier to just get the boot lock with key, but it does mean you'll have 2 keys ::)
May be worth a look for a locksmith who can cut the key to the lock for ease :-\
« Reply #4 on: 15 October 2011, 12:18:16 »
You sure that the lock & key don't match? As the central locking is used most/all the time, the lock gums up & you then tend to struggle to use your key in it. Try lub'ing the lock first, if that doesn't work then follow the guide for the ignition lock & clean up your tailgate lock. If you know that the key & lock don't match, when you have the barrel stripped down, use a selction of tumblers from other locks to make it fit your key.  :y
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« Reply #5 on: 15 October 2011, 12:38:59 »
Might be worth going back and looking at the thread you started in the wanted section, as I have posted a reply on there regarding best option to sort this problem.. :y
Probably easier, and cheaper than replacing the whole cars locks as the boot lock on the saloon is not the same as an estate, as I found out when I needed to order parts from dealer. ;)
I always knew I'd inherit an estate, but I never thought this would be it!
