Author Topic: multiram  (Read 1822 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
multiram
« on: 14 October 2011, 17:26:55 »
hmm me again  :(
have another problem with the facelift compared to the mfl
if i squeeze the pipe that goes (into?) the icv on the mfl the pipe compresses and the car revs change which i take as right
on the f/l if i do the same thing nothing happens you can hear a restriction of air but nothing like what happens on the mfl
is this pointing to an airleak somewhere or the multirams not working ??
once again what is the best way to find out what is wrong?
tia
birdman
  • Chepstow
  • one volunteer is better than ten pressed men
    • 03 2.2petrol gls estate
Re: multiram
« Reply #1 on: 14 October 2011, 20:36:06 »
can someone tell a 2.2 owner what a multiram is,guess its v stuff :D
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: multiram
« Reply #2 on: 14 October 2011, 20:40:51 »
hmm me again  :(
tia
If I am understanding what you your meaning mate... if you squeeze the pipe that goes from the ICV to the Bagpipes the car should stall.. if not then an airleak could be drawing air in to prevent this.... :)
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: multiram
« Reply #3 on: 14 October 2011, 20:42:44 »
As for the Multi Rams not working.... to check them blip the throttle at around 1000 rpm the rear multi ram should activate. Rev the car to 4000 rpm and the front multi ram should activate. :y
Hope that helps
Re: multiram
« Reply #4 on: 14 October 2011, 21:02:56 »
birdman
  • Chepstow
Re: multiram
« Reply #5 on: 14 October 2011, 21:19:56 »
http://www.omegaowners.com/forum/YaBB.pl?num=1153840176/0
Cheers Rob,You learn something everyday!!!!!
fiend61
  • york
  • each to their own
Re: multiram
« Reply #6 on: 14 October 2011, 21:29:49 »
cheers darth
that is exactly what happens on the mfl on the f/l nothing happens  :( so it must be drawing air in from somewhere, the way to check is spraying carb cleaner and listening for engine note change??
also i can check the plumbing side by copying mfl if all else fails i can swap over the multirams, i take it there is no difference as they are both 2.5's ???
thanks
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: multiram
« Reply #7 on: 14 October 2011, 21:40:14 »
Have you changed anything at all on the facelift? like removed the Plenum or Inlet Manifold? are the Bagpipes Jubilee Clips all tight? are the bagpipes correctly on the Throttle Bodies? :)
fiend61
  • york
  • each to their own
Re: multiram
« Reply #8 on: 14 October 2011, 22:04:47 »
the cam cover gaskets have just been done (elite pete) but car was like it before they were changed, i have only just started to use the car as the mfl is getting ummm a bit tired  :( :( and just starting to find out things like this, also the revs blipping every know and then sits at 500rpm then sometimes blips to 1200 rpm and straight back down again, also the revs not changing when turning on/off aircon  :( just things i want to get sorted so it is every good as my mfl was  :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: multiram
« Reply #9 on: 14 October 2011, 22:21:27 »
May have been worth having Pete casting his eye over the airleak  :y
fiend61
  • york
  • each to their own
Re: multiram
« Reply #10 on: 14 October 2011, 23:45:27 »
didnt know i had it then  :(
but from what i can tell its really only a matter of going round everything until i find the leak, and luckily i have the mfl as spares  :y
fiend61
  • york
  • each to their own
Re: multiram
« Reply #11 on: 15 October 2011, 15:48:22 »
had a good look round and carb cleaner everywhere, cleaned out icv and things are alot better now  :y  BUT (there is always one  :( ) i can get the front multiram to work but for the life of me i cannot get the rear one to work  :'(  any ideas ???
tia
