Author Topic: Coolant Level Check  (Read 1599 times)
MV6Matt
  • London
    • No car since 2022....
Coolant Level Check
« on: 14 October 2011, 18:53:12 »
Hi everyone,
I'm getting the above message up on the display.
Looked in the tank and sure enough needed topping up.
Not having any effect, however.
Anyone can tell me why it's refusing to clear with coolant up to the line?
Matthew
(thanks Ian)
Re: Coolant Level Check
« Reply #1 on: 14 October 2011, 19:05:43 »
Knackered sensor most likely.Quite common.
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #2 on: 14 October 2011, 19:05:54 »
Possibly faulty float switch in the header tank
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 14 October 2011, 19:21:48 »
Buy yourself a new Coolant Reservoir mate from Vauxhall for around £30 to sort that out  :y
MV6Matt
  • London
« Reply #4 on: 14 October 2011, 19:28:36 »
Thanks all for your replies
Vaux here I come.................... ::)
(thanks Ian)
kingycos2
« Reply #5 on: 17 October 2011, 17:29:10 »
The header tank no longer comes with the sensor as standard. Its now 2 seperate parts. You can buy the sensor on its own now saving a few quid...
MV6Matt
  • London
« Reply #6 on: 17 October 2011, 20:17:22 »
Thanks for that helpful tip!
Matthew
(thanks Ian)
« Reply #7 on: 18 October 2011, 07:15:22 »
Do you have part numbers?
there was always 2 tank options, 1 with, 1 without sensor.
Never seen the sensor available on its own.
Often near impossible to remove the old one as well.
From EPC.....it doesnt seem to be available to buy: listed as non serviced and has no part number.
« Last Edit: 18 October 2011, 07:24:07 by Jimbob »
