Author Topic: Airbag light still on.............  (Read 2331 times)
MV6Matt
  • London
    • No car since 2022....
« on: 14 October 2011, 19:34:03 »
Thought this was fixed. (why am I ever so hopeful?)
Light came back on after about 4 weeks.
Still getting code 31 Drivers squib high resistance
A plea for help, really.  :'( :'(    Any one in London/visiting/passing through able to sort this?
Matthew
(thanks Ian)
Re: Airbag light still on.............
« Reply #1 on: 14 October 2011, 19:36:05 »
If your at the Essex meet tomorrow Lazydocker will probably have a tool with him which should be able to turn it off, or at least find out why its on.
MV6Matt
  • London
« Reply #2 on: 14 October 2011, 19:37:52 »
Hello Albs...................
Alas, no.
I would have asked directly if I were coming, but not able to.
Hey Ho
Matthew
(thanks Ian)
« Reply #3 on: 14 October 2011, 19:43:50 »
Matthew
steering wheel? Usually either the airbag itself (common) or contacter unit (less common)
MV6Matt
  • London
« Reply #4 on: 15 October 2011, 08:48:28 »
Matthew
Nope, like I said in my original Post the code is 31 Drivers SQUIB high resistance.
The wiring to the airbag in the side of the seat.
Anyone help me find a permenant fix?
Cheers
Matthew
(thanks Ian)
« Reply #5 on: 15 October 2011, 09:19:09 »
ok, in that case the usual suspects remain the airbag itself, its connections to seat loom (there was a bulletin about that) or seat to car loom connections
« Reply #6 on: 15 October 2011, 09:20:00 »
Matthew
Cheers
Matthew
SQUIB normally refers to the ring behind the steering wheel ;)
« Reply #7 on: 15 October 2011, 09:22:25 »
Matthew
Cheers
Matthew
in SRS terms, its any airbag
not got tis to check which a 31 applies to - it does run under webOS ;D
« Reply #8 on: 15 October 2011, 09:38:09 »
Matthew
Cheers
Matthew
In that case I stand corrected... But I've only ever known it referring to the wheel
« Reply #9 on: 15 October 2011, 10:59:03 »
A squib is a miniature explosive device
http://en.wikipedia.org/wiki/Squib_(explosive)
But AFAIK "31" is a generic code, so the question is whether they mean 'Drivers [wheel] squib' or 'Drivers [seat] squib'.. which I don't know - I presume the OP has the service manual which tells him, though, hence he knows it's referring to the seat not wheel?
« Reply #10 on: 15 October 2011, 14:24:39 »
checked, 31 is wheel bag
MV6Matt
  • London
« Reply #11 on: 15 October 2011, 21:50:53 »
Thank you very much for all the replies.
I've certainly learnt something today.
Not sure I'll be returning to the place I took it previously.
I've been fairly insistent about the side air bag as I have been under the impression that that's where I should have been looking...
There's a big difference between Squibs and Squabs.
So Steering wheel Air bag it is. Does this mean replacing or is it a fixable commodity?
Matthew
(thanks Ian)
« Reply #12 on: 15 October 2011, 21:53:05 »
Matthew
Wouldn`t have thought so Matt :-\
MV6Matt
  • London
« Reply #13 on: 07 November 2011, 05:29:51 »
I'm a bit behind at the moment; As it is an airbag replace, should I get a new one from Vaux - or try fitting other ones from older steering wheels? :-[
Matthew
(thanks Ian)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #14 on: 07 November 2011, 09:29:42 »
Matthew
I would have thought a new one would be cost prohibitive,one of the breakers here should have a known good one
other rides
