Author Topic: Fault codes, what do these mean?  (Read 3795 times)
Andy89
  • Norway
    • 97 3.0 MV6
Re: Fault codes, what do these mean?
« Reply #15 on: 15 October 2011, 15:50:50 »
I found the one for the air to the exhaust, but still not working.
sympthoms while driving are that the car cuts power if i floor it, works fine if i nearly floor it
If i rev the engine i can sometimes get to the limit and sometimes it stoppes on the way up.
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #16 on: 16 October 2011, 03:31:10 »
duff = broken = knackered = shagged = not working
Hopefully one of those translations should work :y
Actually, don't run that one through a translator, sorry  :-[
Why not as that leads to up the duff.  ;D ;D ;D ;D
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #17 on: 16 October 2011, 16:07:49 »
Thanks for the help with the fault codes Seems like they are gone now, but still got the problem.
The problem is that i can't press the pedal to the floor
When i do that the engine cuts power, but if i release just a bit, it works.
Any idea what could be wrong?
« Reply #18 on: 16 October 2011, 17:34:10 »
So no fault codes remain?
Worth checking for air leaks and/or HT issues.
Can you fill out your location and car in your profile, as I can't remember what engine it is - we have too many members to keep track in my head ;D
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #19 on: 16 October 2011, 21:38:53 »
There has been no lights while driving.
I have taken care of one leak with tape, while the new part is on it's way.
But what is HT issues?
  • Auckland
    • Mazda MPV
« Reply #20 on: 16 October 2011, 21:46:59 »
HT = High Tension (ie 25000 Volts to the sparking plugs)
When my 1994 2.5 V6 behaved as yours does I wasted a lot of time (and money) getting codes read and changing the DIS.
Fitting new spark plugs fixed the problem. :y
