Author Topic: Fault codes, what do these mean?  (Read 3794 times)
Andy89
  • Norway
    • 97 3.0 MV6
« on: 14 October 2011, 19:54:45 »
Hi
Can somebody tell me what these are?
38   O2 Sensor 1 Circuit Voltage Low
59   Intake Manifold Valve 1 Voltage Low
Just had my engine out and back in, sympthoms while driving are that the car cuts power if i floor it, works fine if i nearly floor it
Re: Fault codes, what do these mean?
« Reply #1 on: 14 October 2011, 19:57:34 »
Rear multiram not plugged in
The O2 one could be duff sensor, or damaged wiring.
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #2 on: 14 October 2011, 20:00:15 »
Rear multiram is plugged in, but i have changed it from one i hade spare at the front multiram, and they had the same number.
What is duff sensor?
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 14 October 2011, 20:04:52 »
They are the same solenoid but it is either like said not plugged in or a duff solenoid  :y
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #4 on: 14 October 2011, 20:07:35 »
I'm from norway, so I don't understand what you mean about "duff"
And i need to find out what both are
Thanks
Andy
« Reply #5 on: 14 October 2011, 20:13:30 »
duff = broken = knackered = shagged = not working
Hopefully one of those translations should work :y
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #6 on: 14 October 2011, 20:14:41 »
duff means faulty or no good  :y
noel
  • frome somerset
« Reply #7 on: 14 October 2011, 20:16:00 »
he he he
« Reply #8 on: 14 October 2011, 20:17:36 »
Actually, don't run that one through a translator, sorry  :-[
« Reply #9 on: 14 October 2011, 20:19:32 »
I'm from norway, so I don't understand what you mean about "duff" And i need to find out what both are
Thanks
Andy
Defekte  :)
« Reply #10 on: 14 October 2011, 20:23:41 »
Motorstørrelse? 2.0,2.2, 2.5,2.6,3.0 or 3.2ltr
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #11 on: 14 October 2011, 22:00:36 »
This is x30xe
I noticed that it was not plugget after all  :P
But the faultcodes are still there, all of them.
I have removed the air that goes into the exhaust, and i tried to fit a solenoid from the multiram, but that didn't help (Because i can't find the right one  >:()
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #12 on: 14 October 2011, 22:01:24 »
Er du og norsk?  :P
« Reply #13 on: 15 October 2011, 02:59:38 »
« Reply #14 on: 15 October 2011, 09:20:54 »
This is x30xe
the codes will remain for a set number of good starts, if you are using paperclip test. If using code reader, you should notice they change to a Not Present status
