Author Topic: part number required....  (Read 2984 times)
« on: 09 March 2008, 11:18:44 »
an odd one... i need the part number for those little plastic clips that hold the standard Omega floor mats down.
2 for drivers side, 2 for passenger.
Re: part number required....
« Reply #1 on: 09 March 2008, 11:25:02 »
Now I know you have EPC ;)
But as its a dealer only part, you'll have to go to them, and they will know.
Do you need the clips or the bits that are cut in to the carpet?
« Reply #2 on: 09 March 2008, 11:26:17 »
Already got the clips in the floor carpet, i need the clips for the matts.
They don't have the holes for them, so will need to make them.
Drivers side one keeps sliding forwards in mine.
« Reply #3 on: 09 March 2008, 11:39:30 »
IIRC, they come in packs of 4.  My tractor needs them as well, but no clips in floor :(
« Reply #4 on: 09 March 2008, 17:34:02 »
Stealing the thread slightly ...  is it possible to retro-fit both bits ??
I don't have the bits in the carpet .. and the mats in this one move all over the place, so I'd like to fit both parts to nail the buggers down !!
If it is possible part numbers would be really helpful .......   :)
« Reply #5 on: 09 March 2008, 17:45:00 »
yes, the holes will be in the chassis, just need to make the hole in the carpet!
markey mark
  • SLady bitshorpe north lincs
« Reply #6 on: 09 March 2008, 17:53:12 »
i have a shed load jaime pm me your address and will pop a set in post for ya matey :y
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #7 on: 09 March 2008, 19:10:26 »
I need to do this too; I have exactly the same problem.
If there are any going about then I'd happily pay the going rate + p&p.
Entwood, what are you plans for making the holes so they don't fray/fuzzup at the edges?
« Reply #8 on: 09 March 2008, 21:49:09 »
Markey ... is it a shed full of floor bits or mat bits you have ??  or both !!
either way .. I'll willing buy 8 of each .. or whatever you have !!!!!!
Albatross ... until I see the bits I'm not certain ... hopefully the way they fix will prevent fraying .......  :(
Albatross
  • Bedford
« Reply #9 on: 09 March 2008, 22:19:56 »
Do you need 8 for a car then? Or are you doing 2 cars?
If there are enough left, I only need enough for 1 car. I appreciate and accept my place in the queue though.
« Reply #10 on: 09 March 2008, 22:35:30 »
I believe its 4 per mat .... might be wrong .. :(
Taxi_Driver
« Reply #11 on: 09 March 2008, 22:41:59 »
In that case.......look it up yourself tunnie......lazy git  ::) ;D
Albatross
  • Bedford
« Reply #12 on: 09 March 2008, 23:43:35 »
I've just seen these mats
They seem to only have a single clasp at the back of the mat on the driver's side front.
Is there an easy way to clasp your mat here if you don't have the holes already in your carpets?
I like this idea because the clip wll be largely out of site if it is single and that far back.
« Reply #13 on: 10 March 2008, 10:56:09 »
Normally 2 per mat, though never seen clips on rear. Generally, on drivers seems to have them, occasionally passenger....
« Reply #14 on: 10 March 2008, 14:33:36 »
okies .. thanks for that .. so at least 2 possibly 4 needed , both mat and floor bits if anyone knows where or part numbers ??
