Poss. wanted. Abs ecu
Started by RobG, 17 October 2011, 20:20:40
May need an Abs Ecu for a MY `00 F/L 2.5 Auto Elite. Will know for sure in the next day or two. Any knocking about
Sold one which would have been the right one a few weeks ago .Cant remember what year Twiglets 2.5 is,might be a suitable one there if he still has it. :-\
Quote from: Albs on 17 October 2011, 20:33:11
Bloody pointless sentence innit :P :P ;D
Quote from: RobG on 17 October 2011, 20:20:40
I'm amazed that you haven't a suitable ECU from any cars you've broken ......  :o :o :o  ;)  ;D
I wouldnt have one for mine if I needed it either.Have hundreds of other parts that I will probably never need though. ::) ;D
For "may" read "definitely" ;D
Anybody able to assist
twiglet
Does it have to be from a 2000 MY car Rob?
If it isnt from the correct year car it will need to have a chat with tech2 afaik. ;)
Quote from: Albs on 19 October 2011, 20:31:04
MFL onwards 2.5 auto ;)
Got a 3.2 one here, ain`t worth a ***k
twiglet
Quote from: RobG on 19 October 2011, 20:37:16
Check  ;)
You still  also need to find out if its just a wheel sensor rather than ECU.The speedo still works ok, yes ?
If so, it has identical symptoms to my car a month ago - wheel sensor. 5 minute job. ;)
Buy or borrow an ***** reader and find out.If you prefer,I can send you a front and rear sensor to try,but even then afaik it will need the codes cleared anyway. Dont know if that type of code clears from x amount of clean starts. :-\
Quote from: Albs on 19 October 2011, 20:42:51
Nope. If I drive it for about 8 miles the lights go out and I get the satnav back ;D
ECU then. I would post a wanted ad if I were you. :y :D ;D
twiglet
Are you trying to steal my sales Mr Albs sir???   >:(  Keep this up and I'll be holding onto your LPG filter and 2013!! :P ;D
It does probably make sense to try the wheels sensors first, just to illiminate them from you enquiries, so to speak.
If that doesn't work, I'll happily send you down the ECU, again if only to rule it out.  :y
