Exhaust manifold wanted for 2.0L on 2000W plate
Started by BgBLizard, 18 October 2011, 13:25:28
BgBLizard
Hi All
If this could be moved it would really be appreciated.
I am after a exhaust manifold for my sons 2.0L facelift on a 2000W plate if any one could help.
Cheers
twiglet
I've got a 2001MY 2.2 exhaust manifold here, not sure if it's the same though.  Don't suppose you have a part number?   :-\
BgBLizard
Im sure it will be OK thanks :-[
you ok to post?
Twiglet
Does 2l have SAI on, if so, likely that plumbs into manifold, and doubt 2.2 has that...
Quote from: TheBoy on 18 October 2011, 20:00:40
Correct on both :)
BgBLizard
We had to remove a pipe with two small connections to the manifold so that would be the SAI.
Manifold is not here at the moment so cannot check PN but asked this qustion before and got this answer
http://www.omegaowners.com/forum/index.php?topic=94072.msg1178849#msg1178849
If fitting a 2.2 manifold, strip out all the SAI system but leave the solenoid valve with it`s electrical connection in place.
BgBLizard
Thanks Rob
Possible to use a resistor instead of solenoid to fool the ecu.
BgBLizard
Thanks twiglet
Tried to contact you but go this "PM could not be sent to 'twiglet' as their inbox is full!"
twiglet
