Author Topic: Stuff coming out of exhaust!  (Read 4273 times)
gareth.
  • Endor forest, South Wales
    • 2.5 v6 cdx leather
« on: 18 October 2011, 23:05:53 »
It seems that the silencing fibers are coming from my exhaust at a fair rate, when I park in work I have a new load hanging out of the exhaust.
Should I keep pulling it out?
Do I need a new back box ?
If it's not broken, don't fix it.
Re: Stuff coming out of exhaust!
« Reply #1 on: 18 October 2011, 23:09:02 »
Yep you need a new back box - the eventual effect of the wadding coming out for others has ranged from "It got loud" to "There was an enormous bang and then the back box exploded"..
Eternalcar (on ebay) seems to be recommended from time to time, although a couple of folks reported fitment issues recently.
gareth.
« Reply #2 on: 18 October 2011, 23:19:06 »
Oh Sh** :o
« Reply #3 on: 18 October 2011, 23:20:49 »
Exploded makes it sound worse than it is, really.. the whole thing just sort of peels open like a tin of sardines (and the remains of the wadding falls out) - that's if the wadding happens to block the pipe, of course.
gareth.
« Reply #4 on: 18 October 2011, 23:24:03 »
So I should definitely pull it out then incase I cause it to block, you never know it might stop coming out :)
« Reply #5 on: 18 October 2011, 23:36:14 »
.. and if it does split, make sure that the escaping hot gases aren't going to melt a hole in the plastic fuel tank just next to it. :o
« Reply #6 on: 18 October 2011, 23:44:30 »
Pull it out. :y This happened to mine and it lost a hell of a lot of power until I discovered why.Bent a hook on the end of an old wire coat hanger and fished it out with that.The car then ran OK (but a little noisier) until a changed the box a few months later. :y
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« Reply #7 on: 18 October 2011, 23:47:05 »
Then it could EXPLODE!!!.... lol.... (joke)
Wouldn't be good melt a hole in the tank but I very much doubt it could happen.... Unless anybody has seen this of course???
« Reply #8 on: 18 October 2011, 23:54:25 »
Yep, it's happened. That's why I mention it. ;)
« Reply #9 on: 18 October 2011, 23:59:28 »
YES!!!
Driving back from scotland on m6. Rear box was split . Eventually burnt huge hole in fuel tank. Lost 90 quid of fuel on the road between 2 junctions. I will never know how it didn't blow up...
gareth.
« Reply #10 on: 19 October 2011, 00:06:56 »
I had confidence before tha last few posts, I will be there tomorrow with my wire :y
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #11 on: 19 October 2011, 08:38:26 »
Didn't know about the exploding bit, but my old saloon rear box started shedding it's guts. I kept pulling it out til it run out and kept the car running. I never had an issue with it at all, guess I was extremely lucky  ::)
AKA - Mr Bracket
« Reply #12 on: 19 October 2011, 08:44:08 »
That's why yours didn't explode ;) ;) It's only if it gets blocked that the pressure builds up
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
« Reply #13 on: 19 October 2011, 09:08:57 »
Did exactly the same with mine. Once I got the majority out I shoved the wet and dry vacuum up it to get the remainder out. It ran underpowered and used more fuel. Put a cats back Eternal system on it once funds were there.  :y :y
The happiest people don't have the best of everything,
they just make the best of everything they have.
pauls
  • By the sea minehead
    • Bmw x3
« Reply #14 on: 19 October 2011, 10:44:39 »
Morning I had this problem earlier this year. No warning foot down to overtake and Bang the back end felt like it lifted up in the air, I pulled over and went round the back my backbox had peeled back like a bananna and left a pile of stuffing all over the road. :'(
