Pages: 1 [2] 3  All   Go Down
Author Topic: Traction Control.  (Read 5733 times)
Re: Traction Control.
« Reply #15 on: 21 October 2011, 19:38:17 »
Switch cureently en route via Royal Snail. :y............probably not the problem but at least you will always have a spare. ::)
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« Reply #16 on: 21 October 2011, 19:56:23 »
Sounds well complicated!
So if i turn it off from the switch its 100% disabled?  Might change the switch first then incase that is faulty....
I might have a switch here you can have just to eliminate it Paul.If you want to nip up and see me when Im at work,I should be able to read the codes for you too. :y
Car is OTR at the moment mate as the drivers door lock mechanism needed sorting (cheers Twiggy ;) ) and i'm trying to sort the battery drain that is causing the NEW battery to go flat in 2-3 days as well as the T/C issues, just want to sort a few niggles.
Any chance of popping that switch in the post  ;)
I have an ex-police car that eats power but as soon as I disconnect the drivers heated seat plug down by the sill it's ok....
Also, my TC wires were cut behind the switch and taped up.... Souldered the back together and TC works fine...  :y
« Reply #17 on: 22 October 2011, 03:20:41 »
Had similar issues with mine. Plod had fitted a cut off switch to the TC. When they cleared all their gubbins, they rejoined the two wires where their switch had been in the steering column. The only definitive solution was to remove all their butchering and repair/make good any joins/breaks/connections in the VX loom. Now good as gold.
They used white wires with a blue trace iirc for the TC on mine. Ran from the loom behind the switch, and over to somewhere between the fuse/relay box and the instrument cluster. Yours is a similar vintage so might apply to yours too... Same force and all...
Get as much of the centre console looms as possible, 6-10" with plugs, cut the plugs from your looms,(or where plod cuts are/were), and rejoin the new looms/plugs to the car loom. done properly it shouldn't give you any further problem...
HTH, Al.
« Reply #18 on: 22 October 2011, 03:30:07 »
As an aside. I've fitted heated seats all round, rear electric windows, and a selection of electrical odds and ends with no real issues. My battery only goes flat if I leave the TV tuner on standby::).
The car did have a new alternator just before I bought it, and only recently had to replace the battery.
When I changed the interior and added bits and bobs, I went through the entire car and removed about 20m of 'left for dead' wiring :0, and repaired/replaced the original loom. Have had no electrical accessory issues since.
Takes time, but worth doing imho.
« Reply #19 on: 22 October 2011, 09:33:32 »
Thanks for all your detailed answers fellas, much appreciated!
I get how its meant to work, my issue is that on occasions when i do decide to turn it off it just won't - no matter how hard or repeated press the button  >:(  It just won't turn off, then sometimes it will turn on and off like it should which makes me think its the switch or the wiring behind as the switch wasn't there when i got the car, the police used the +feed for some of the equipment.
Sounds like the switch has been wired to something that's not always active, IMHO. If the plod have messed about with the wiring anything's possible.
I'll have a look at the wiring diags when I get a chance and see how it's supposed to be wired. :y
Ah that would be smashing, thanks Kevin  8) :y ;)
I think its just Push to Make to ground a wire from ECU...
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« Reply #20 on: 29 October 2011, 19:02:30 »
Did you manage to have a look mate?  :y
P6UL K
  • Dartford, Kent
« Reply #21 on: 22 November 2011, 18:46:49 »
BTTT for Mr Kevin Wood  ;D
« Reply #22 on: 22 November 2011, 19:21:38 »
Ermm. Yes. ::)
Brown wire with red tracer from pin 31 of the ECU, grounded by the switch.
I can imagine that if the ground wire to the switch has come adrift, whether it works might depend on whether the headlights are on. Does the illumination in the switch work?
P6UL K
  • Dartford, Kent
« Reply #23 on: 22 November 2011, 19:26:24 »
I'll try and get the stereo surround off over the weekend and see the wiring..
Yes it does illuminate Kevin....
P6UL K
  • Dartford, Kent
« Reply #24 on: 15 December 2011, 13:14:18 »
**UPDATE**
After further investigation by another mate who seems most interested in my problems, it turns out that the T/C button only works if the headlights are switched off!  ::) ::)
Works fine otherwise, turn the lights on and it stops working! Very odd but no doubt is down to me rewiring all the switches around the radio when i got the car as TVP had made a right hash of it - And so have i it would appear lol
Any comments? ha ha  ;D
P6UL K
  • Dartford, Kent
« Reply #25 on: 18 December 2011, 22:51:02 »
All wiring now checked and the issue still pursists, what on earth could it be?!
« Reply #26 on: 18 December 2011, 23:30:01 »
The ground connection to the switch. Current through the illumination circuit is pulling the ground connection up to the point where the switch doesn't ground the line from the ECU.
(Ground wire from the switch is shared by the bulb in the switch)
« Reply #27 on: 18 December 2011, 23:36:30 »
Mine played up for a while, took 3 seperate attempts to sort it. :'(
P6UL K
  • Dartford, Kent
« Reply #28 on: 19 December 2011, 06:11:36 »
Thanks Kevin,  :y  i've messaged what you've said to my mechanic friend to have a further look - as i'm off to work.  :'(
« Reply #29 on: 19 December 2011, 21:23:46 »
Just re-read and had a 'Eureka' moment. The switch has been earthed through the Grey/Yellow switch illumintion wire as well as/instead of the Brown earth wire. ::)
Might I politely refer you to my earlier post :P:
HTH, Al.
Again HTH, Al. :y
Pages: 1 [2] 3  All   Go Up
Page created in 0.029 seconds with 16 queries.
