Pages: [1] 2 3  All   Go Down
Author Topic: Traction Control.  (Read 5735 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
Traction Control.
« on: 20 October 2011, 13:42:21 »
Afternoon one and all,
Can anyone explain in detail how the traction control works on the Omega?  Mine is playing up and sometimes turns itself on or off at will and on occasions when i try to turn it off it won't turn off or if i do mangae to turn it off, it stays off for a bit and then turns itself back on again!  Very frustrating!
Does it run thru the ecu off of the rear ABS sensors or is it much more complicated than that?
Ta  :y
Re: Traction Control.
« Reply #1 on: 20 October 2011, 13:54:25 »
The speed of the driven wheels are monitored through the ABS system and, if a wheel is slipping, the brakes on that side are applied to transfer the torque to the other back wheel. If that doesn't work the system talks to the engine ECU which responds by dropping cylinders and/ or retarding the ignition to reduce power on the non-dbw cars. DBW cars appear to lose power by reducing throttle, as it's smoother.
If the TC light is ON the system has been disabled by pressing the button OR there's a fault with it. If the light's off the system is enabled (this is the default after starting the car).
It sounds to me like there's a fault which is causing it to light the TC light, to be honest.
2woody
  • Northumberland
« Reply #2 on: 20 October 2011, 16:13:31 »
cars up to about 1998.....
no brake intervention.
ECU drops cylinders
cars from 1998 up to DBW.....
brake intervention and ignition retard
DBW cars.....
throttle opening reduction
P6UL K
  • Dartford, Kent
« Reply #3 on: 20 October 2011, 17:17:28 »
Sounds well complicated!
So if i turn it off from the switch its 100% disabled?  Might change the switch first then incase that is faulty....
« Reply #4 on: 20 October 2011, 17:22:02 »
If you press the switch so the light is on, TC is disabled. If the light is off, it's enabled.
I've never known a switch to fail. What are the symptoms? If you start up and drive off the light is off, yes? If it comes on of its' own accord I'd say you have a fault and it's indicating a stored fault code.
I would get the ABS codes read before doing much else, TBH. :-\
« Reply #5 on: 20 October 2011, 18:23:12 »
To clarify what Kevin Wood and 2woody have said:
The system is enabled if the light on the dash is OFF, and disabled if the light is ON
Pre 1998 cars, TC cuts cylinders
Post 1998 cars, TC applies brake to rear wheel that is losing traction, if that does not resolve the situation, will start to cut cylinders (2.5/3.0) or reduce throttle (2.6/3.2)
« Reply #6 on: 20 October 2011, 18:28:39 »
I might have a switch here you can have just to eliminate it Paul.If you want to nip up and see me when Im at work,I should be able to read the codes for you too. :y
« Reply #7 on: 20 October 2011, 18:29:48 »
Should say - switch is FOC to Paul as I owe him a favour.Not trying to sell anything in this area. ;)
« Reply #8 on: 20 October 2011, 18:30:59 »
Its a simple Push To Make switch, thus if you just remove the switch, the system should remain enabled (dash light OFF) inless there is a fault.
P6UL K
  • Dartford, Kent
« Reply #9 on: 20 October 2011, 19:19:04 »
Thanks for all your detailed answers fellas, much appreciated!
I get how its meant to work, my issue is that on occasions when i do decide to turn it off it just won't - no matter how hard or repeated press the button  >:(  It just won't turn off, then sometimes it will turn on and off like it should which makes me think its the switch or the wiring behind as the switch wasn't there when i got the car, the police used the +feed for some of the equipment.
P6UL K
  • Dartford, Kent
« Reply #10 on: 20 October 2011, 19:24:01 »
Car is OTR at the moment mate as the drivers door lock mechanism needed sorting (cheers Twiggy ;) ) and i'm trying to sort the battery drain that is causing the NEW battery to go flat in 2-3 days as well as the T/C issues, just want to sort a few niggles.
Any chance of popping that switch in the post  ;)
« Reply #11 on: 20 October 2011, 19:33:19 »
Assuming I can find it yep.Will have a look in the morning and let you know.As said,it may well not be that,but at least you can eliminate it from your enquiries. :y
« Reply #12 on: 20 October 2011, 23:40:34 »
Sounds like the switch has been wired to something that's not always active, IMHO. If the plod have messed about with the wiring anything's possible.
I'll have a look at the wiring diags when I get a chance and see how it's supposed to be wired. :y
2woody
  • Northumberland
« Reply #13 on: 21 October 2011, 08:33:39 »
would have saved time if you'd said that first. The shoddy nature of the Police wiring will undoubtedly be the cause.
I'm on my fourth Police car now - every single modification to all of them by Police has been done in a less than competent fashion - some of them downright dangerous.
P6UL K
  • Dartford, Kent
« Reply #14 on: 21 October 2011, 19:05:03 »
Ah that would be smashing, thanks Kevin  8) :y ;)
Pages: [1] 2 3  All   Go Up
Page created in 0.096 seconds with 16 queries.
