replacement speakers
Started by al brown, 20 October 2011, 20:02:19
al brown
What size(inch), type(mid, low etc) and rated(ohm) speakers would I need to replace those in my car (97 elite estate without Bose).
One of the front door speakers isnt the best any more and I figure if I am going to replace one it would be best to change them all as 1 new speaker will make the rest sound odd.
As I understand it the fronts are split into 2 with the tweeter being up by the mirror. So, is it worth replacing those too.
Many thanks    Al
If it aint broken, you aint trying hard enough
mega3.0v6
I think they are 16.5 front doors.
Dave DND
You will need some speaker adaptor rings to make them fit - not expensive, generally only a few quid or so - My supplier doesn`t have an eta at teh moment, so cannot help on them, but as for speakers, try these
http://www.dndservices.co.uk/sre1721s.html
Radio & Decoding Technician
al brown
Cheers Dave, I have plenty access to metal at work and can easily knock up some plates myself. Would those tweeters fit in by the mirrors and what would I need for the rears please?
Al
Brikhead
Pop down to your local scrap yard and remove the front speakers from a Vectra, they are the same.
No need to replace the tweeter, they NEVER fail through normal use.
Quote from: Brikhead on 23 October 2011, 11:55:20
But if you are going to that effort, why replace them with the tat that GM fit. May as well put something a little better in :y
Brikhead
Quote from: TheBoy on 23 October 2011, 16:31:00
If you followed that logic then you'd find yourself driving a B.M.W.
I've always thought Vx. speakers weren't that bad really, once you feed them a decent signal...
Quote from: Brikhead on 24 October 2011, 20:13:15
You will struggle to find a worse speaker...
Dave DND
Quote from: TheBoy on 24 October 2011, 21:00:42
Paper cone speakers with a surround that has bio degradeable characteristics - yes, I have to agree that the Vx speakers are about as bad as they come.
QuoteIf you followed that logic then you'd find yourself driving a B.M.W.
Not sure about BMW, but you won`t find me driving an Omega for sure !!  :P
