Author Topic: Cleaning oil strainer - any tips?  (Read 5529 times)
Boatboy
  • St Albans
« on: 21 October 2011, 11:20:50 »
Like how long it should take etc.
All this because the top end on 1-3-5 is generally chattery and has been for some time, but lately is getting worse. Sounds worse in the cabin than under the bonnet. Manifold and downpipe gaskets appear sound and no obvious problems around EGR.
Intend to clean the strainer and do some quick oil changes and if things dont improve may have to inspect the lifters themselves. A dose or two of Wynns lifter special has made no difference.
Having searched the forum I'm not sure if i will need a gasket or sealant for the sump, and if sealant is cam cover sealant acceptable?
TIA
Steve
Every start's a bonus!
03 2.6 Elite estate. Bose my A***
Re: Cleaning oil strainer - any tips?
« Reply #1 on: 21 October 2011, 14:38:09 »
Grey sealant (type used for oil cooler) :y
Boatboy
  • St Albans
« Reply #2 on: 22 October 2011, 09:07:18 »
Cheers.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 22 October 2011, 09:22:54 »
Steve, drain the oil, remove 20 E10 torx headed bolts. I usually leave a couple of bolts at one end so the sum pan does not fall straight down when you prise the pan slightly from the sump casting seal. Undo the two bolts again E10 headed which hold the oil level switch to the inside of the sum pan.
There are four bolts again E10 headed tore bolts holding on the stainer one of which is a little difficult to get to under the return pipe.
Clean it and happy days. Like jaime said grey sealant
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« Reply #4 on: 23 October 2011, 09:27:48 »
Hi guys, this is a job I think I need to do....
When you say "grey sealant" exactly which sealant???
« Reply #5 on: 23 October 2011, 09:42:24 »
its the sealer for oil coolers.
HockeyDave55
  • Milton Keynes
« Reply #6 on: 23 October 2011, 09:46:08 »
Lol... And that would be???
« Reply #7 on: 23 October 2011, 09:47:55 »
93165267 SEALANT (GREY)
« Reply #8 on: 23 October 2011, 09:48:05 »
« Reply #9 on: 23 October 2011, 09:48:37 »
sorry, don't understand?
if you are after the loctite/whatever number, sorry, no idea
HockeyDave55
  • Milton Keynes
« Reply #10 on: 23 October 2011, 09:50:35 »
I was just about to go into VX and say.... Can I have some grey sealant please? Lol... Thanks guys..  :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #11 on: 23 October 2011, 10:59:28 »
Quote from: RobG link=topic=94821.msg1188552#msg118 :-\8552 date=1319359675
I get rather puzzled with people who request the part numbers for everything. If you did go into Vauhall and asked, "I need the grey sealer thats used for the oil cooler, and the sump pan please" they would give you the right stuff. :)
  • Auckland
    • Mazda MPV
« Reply #12 on: 23 October 2011, 11:25:07 »
They wouldn't dare sell the wrong stuff to 'The Master' :D
Some lesser mortals might end up dealing with the work experience boy and it is always nice to have the advantage of superior knowledge. ;)
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #13 on: 23 October 2011, 11:44:26 »
I have not thought of it like that being fair as the VX I use, have always been very good.... So point taken :)
P.S. The Master is Mark DTM I am just his Apprentice :-*
Boatboy
  • St Albans
« Reply #14 on: 23 October 2011, 20:20:15 »
Ha!
Local vx had no grey. After a word with one of the spanner spinners parts guy said black (as per cam covers) was as good as any.
Job done and driveway still clean so cant be all bad. Strainer 'looked' clean, but a poke behind the shroud revealed a lot of crud. Mostly looked like cam cover sealant :-X
Anyway, job done and the noise is still there. At least that's one cause eliminated. At 165k and a shot body, wondering if it's just a case of running her into the ground whilst keeping an eye on the for sale section.
Steve
