Author Topic: i now know how TB feels...  (Read 4372 times)
Re: i now know how TB feels...
« Reply #15 on: 22 October 2011, 14:13:16 »
But wtf is the lappy doing in the Laundry basket?  :o
Precisely  >:(
Look on the bright side.. at least it wasn't the freezer!  ;D
how bloody big is that laundry basket???
 ;D ;D ;D ;D ;D The computer, not the laundry basket..  :P ;D
Although.. if it were summer - nice cool shreddies, mmmm.  ;D
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #16 on: 22 October 2011, 15:12:14 »
Bugger, it seems I may have a sticky lpg injector or the dis pack is starting to go.  Running that one cyl on petrol.for now.  :'(
On the plus side the code for the radio was written on the side so no need to fork out for it ::)
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #17 on: 22 October 2011, 15:14:46 »
Precisely  >:(
i was imagining the freezer being in the laundry basket.....       going to be quite some effort hanging that out on the line....
MaxV6
  • Oxford UK
« Reply #18 on: 22 October 2011, 15:16:03 »
Precisely  >:(
« Reply #19 on: 22 October 2011, 15:31:05 »
 ;D ;D Arguably I could do with hanging mine out.. might air the fridge part out a bit and stop it smelling like something rotted in there. (Which er, might be because something did..)
Guffer - that's a sod about the sticky injector :( Can you get LPG injectors rebuilt like petrol ones? It cost me very little to have four petrol injectors rebuilt & flow tested..
MaxV6
  • Oxford UK
« Reply #20 on: 22 October 2011, 15:34:55 »
clean out the fridge using a solution of bicarbonate of soda....   end of smelly problem....
« Reply #21 on: 22 October 2011, 15:36:43 »
 :y That's on my (long) list of 'things to do around the house' .. the trouble is, the list of 'things to do sat in front of the telly' or 'things to fiddle with in the garage' usually wins.. ;D
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #22 on: 22 October 2011, 17:51:03 »
clean out the sticky injector using a solution of bicarbonate of soda
 :o  ;D
I feel like a military academy. Bits of me keep passing out.
MaxV6
  • Oxford UK
« Reply #23 on: 22 October 2011, 17:53:09 »
not convinced that 's a good idea Osprey...   but hey, why not give it a go....  and get back to us on it's success, or failure.....   :y
« Reply #24 on: 22 October 2011, 17:56:12 »
Did some googling: http://forum.landrovernet.com/showthread.php/200450-Cleaning-Gas-(LPG)-Injectors
Seems you're pretty safe to clean the injectors with WD40 as it's a mild solvent, and this fella seems to have had good success curing the same problem..
IIRC the dis pack uses one coil per 2 plugs? So it'd seem likely that would affect two cylinders rather than one, leaving the most likely culprit the LPG injector/nozzle, HT lead or spark plug?
Gaffers
« Reply #25 on: 22 October 2011, 18:07:16 »
Cyl 6 works fine on petrol and the plug and ht leads are new.  If the coil in the dis pack was on the way out it might not have enough juice to do 2 fly with lpg....not the most likely which is the sticky injector diagnosis.  Never mind, I'll have a look tomorrow morning but I might just run it down south with 5/6 of the engine on lpg rather than risk the entire back of injectors before I get home.
« Reply #26 on: 22 October 2011, 18:30:10 »
Guffer I understand you , as most of men share the same faith.. in those days I hope someone dont provoke me.. :-\
LJay
  • North Wales
  • The Acrobatics Queen!
    • 3.2 - MV6 Big Blue!
« Reply #27 on: 22 October 2011, 18:36:47 »
Precisely  >:(
 ;D
Reminds me of when a school mate of mine got busted for having a party while his parents were away for the weekend.
"What's this in the laundry basket"
"er.. :-[ Don't know. Has the cat had an accident again?"
"How long has the cat been smoking cigars?"
"Er... wibble :-X"
I hope today is a better day, Guffer. :y
At least it wasn't used, errrr, 'protection equipment' in your mate's parents bed  :-[
I dunno whats worse, leaving used jonnies in someone elses bed or the fact you did it in your mates parents bed! :o Eeuww!
Been there, fallen over it!
« Reply #28 on: 22 October 2011, 18:40:00 »
Precisely  >:(
 ;D
"Er... wibble :-X"
I think you have the wrong end of the stick...
It was clearly a used teabag caddy he left lying there :y
Gaffers
« Reply #29 on: 22 October 2011, 21:20:47 »
Why was he having sex with that on the end of his k....... ::) ;D
