Author Topic: Silly question, tech2  (Read 3143 times)
Stan_2
  • London
    • YR 2000 GLS Auto 2000cc
« on: 22 October 2011, 13:48:33 »
I went to my local garage to ask if they could do a diagnosis, the person who does it wasn’t there and told me to come back Monday.
He asked me if I had a 9 pin plug, I didn’t have a clue,  :D is it the tech2 that does the diagnosis that I have read so much about?
Also can someone tell me where it is situated?
YR 2000  GLS Auto  2000cc 16V
    • 530D M Sport, 330i Coupe
Re: Silly question, tech2
« Reply #1 on: 22 October 2011, 14:09:36 »
Your car will have a standard(ish) OBDII socket located under the steering wheel in the fuse/relay box location.
Older Vauxhalls have an ALDL link.
« Reply #2 on: 22 October 2011, 14:10:37 »
The plug is in the panel underneath the steering wheel and is shaped like this:
(Not a picture of an Omega, obviously, but the socket looks a lot like that)
It has 16 pins.
Tech2 is the genuine Vauxhall diagnostic computer, highly unlikely any garage outside of Vauxhall or one of the few folks on here will have one, however, they'll probably just have a generic OBD2 diagnostic computer or possibly an "My Naff Code Reader" (maybe even genuine if it's a proper garage).
« Reply #3 on: 23 October 2011, 00:18:51 »
clearly the bloke doesn't have a clue, would you really wanting p,ugging j
« Reply #4 on: 23 October 2011, 00:28:04 »
yeah find another garage which knows what the fek they are doing!
« Reply #5 on: 23 October 2011, 00:41:26 »
It`s a 2.0ltr. What`s wrong with a paperclip ???
« Reply #6 on: 23 October 2011, 09:44:49 »
presumably wanted other systems checks
Stan_2
  • London
« Reply #7 on: 23 October 2011, 17:43:22 »
Thanks for the help & suggestions.
I thought a diagnosis would tell me why my airbag light is on all the time and the emissions light on 80% of the time.
I’ve only had the car about a month and the lights were on when I brought it. I put it through the M.O.T a couple of days after I got it.
It failed on emissions and cost me £90 quid to have some welding done on the exhaust, but the light is still on.  :(
I’m hoping diagnosis will tell me why the lights are on.
« Reply #8 on: 23 October 2011, 17:56:24 »
Does a nearby member have the correct equipment.
If that garage doesn't even know what plug it has, I doubt they would understand the data coming back, unless they take the fault codes on face value (bad move) and willy nilly change parts.
Stan_2
  • London
« Reply #9 on: 24 October 2011, 18:44:14 »
I took your advise, didn't bother going back to the garage. When I get chance I will book it in at a stealer as you call them.  :(
« Reply #10 on: 24 October 2011, 18:46:51 »
Where are you in London? If you're on the West side then there's a member with a Tech2 who knows how to use it not a million miles from you.
Stan_2
  • London
« Reply #11 on: 24 October 2011, 18:54:14 »
I'm in SW, near Croydon
« Reply #12 on: 24 October 2011, 18:55:51 »
Try and find a member nearby with right tools. Dealers aren't much use for Omegas either in ost cases  :'(
« Reply #13 on: 24 October 2011, 18:58:18 »
A trip to Kevin Wood wouldbe the best option imo. :y
« Reply #14 on: 24 October 2011, 19:04:59 »
Yep, what Albs said - KW isn't all that far from you, really (a jaunt down the M3).
Or if a more generic reader works on the 2ltr, I'm a bit further up the M3 toward London (but someone else will have to confirm that, as I don't know - never having tried :))
