Author Topic: Self Levelling Rear Shocks (poss)  (Read 3002 times)
« on: 23 October 2011, 16:40:18 »
I'm still pondering what to do, one option is to put SL rear shocks on my 3.2 & then I'll have standard Elite setup all around.
My millage is very low at the moment, so considering second hand.
Any of you breakers got a pair in decent condition?
Re: Self Levelling Rear Shocks (poss)
« Reply #1 on: 23 October 2011, 16:44:45 »
I dont have any,RobG sold his (only pair afaik) to Bigyin recently,Pretty sure Twiglets elite breaker has had S/L removed (I had a look under it last week.It definetly had newish aftermarket shocks, but I dont believe they were S/L. might be worth checking with him though.
Other than that,the usual suspects or Omegaspares I suppose. :-\
« Reply #2 on: 23 October 2011, 17:00:44 »
Never really seen used SL shocks in good nick, due to the air bladder, you get masses of corrosion under it, and the result soon becomes...  ...well, you've seen it. <60k miles as well.
« Reply #3 on: 23 October 2011, 17:02:47 »
true, but that would be cheapest way to get a complete standard setup, not a mixture.
« Reply #4 on: 23 October 2011, 17:40:56 »
Are elite fronts different to std? Dunno tbh.
You have std rear shocks and std KYB (shagged, mind, but in one piece) at rear.
Therefore, std suspension.
Whilst those springs may get through MOT, accept they are knackered. But will get you through decision time ;)
The SL springs have a cost attached, so probably not the road for you to go down ;)
« Reply #5 on: 23 October 2011, 17:41:20 »
Unless you want bog std elite.
« Reply #6 on: 23 October 2011, 17:45:49 »
Seemingly not the springs. Cant see anything obvious on shocks, but get me the ident code off one side :y
« Reply #7 on: 23 October 2011, 17:47:40 »
If your going to change the suspension you might as well go for B4 shocks and a decent spec of springs.Then some time later when time/funds etc allow,uprate the front to match imo. ;)
Unless you particu;arily want Elite setup for towing or similar ?
« Reply #8 on: 23 October 2011, 18:11:14 »
Won't be towing...
TB - Will do, I thought Elite fronts were different. But if they are standard & I already have standard rear shocks, a pair of new springs say Boge will be cheap enough & I'm then got a base to go from.
Considering cost of MV6 setup, B4's is possible. But then again after 7 years I've found standard suspension ok.
« Reply #9 on: 23 October 2011, 18:18:20 »
Won't be towing...
Cheap option, std rear springs.  When any of shocks get tired, B4 the lot.
« Reply #10 on: 23 October 2011, 18:19:36 »
Sounds like a plan
« Reply #11 on: 23 October 2011, 20:17:56 »
I put B4,s on the rear of mine recently.Made a very noticeable difference over standard. :y
Front seems far too soft now though,so will have to have a think about that in the not too distant.
bored bigyin54
  • south wales
    • black beast
« Reply #12 on: 25 October 2011, 17:08:39 »
well i got no probs with the ones i got of robg
« Reply #13 on: 25 October 2011, 17:17:49 »
Decided to stick with standard setup all around for now then go from there. So no longer needed  :y
2woody
  • Northumberland
« Reply #14 on: 26 October 2011, 09:26:56 »
I've got a couple of decent sets of saloon self-levellers if necessary
