ccr 2006 sound fault
Started by will_v6_cdx, 24 October 2011, 17:19:51
will_v6_cdx
i have a ccr 2006 fitted in my omega,
when listening to the radio its fine but when you listen to cd the sound only comes out of rigt side of car
has anyone come across this fault before.
thanks
freecall666
would think by what you saying the cd unit is on its way out. have you tryed cleaning it with disc cleaner just in case it just a bit of muck.
Solar charger fitted.
If not Broke dont fix it..
Dave DND
Not uncommon to be a dodgy joint on the red connector where it solders to the underside of the main pcb of the radio top section.  Seperate the radio and cd mech and you`ll see the connector on a ribbon cable, check the socket where it is soldered.
Known it to be a laser also though   :'(
Radio & Decoding Technician
www.dndservices.co.uk
will_v6_cdx
not tried cleaning it, if it is a fault with the laser or the unit i will try and source a replacement,
i thought i was because i was playing mp3 cds in it but tried a proper cd and still the same.
thanks for your help
By "mp3 CDs" I presume you mean audio CDs you've burned yourself? (Since the unit can't play mp3 files natively)
Check the red connector between the 2 halfs of the stereo. Also check the vertical board in the CDC section is fully home.
I wouldn't even bother with a laser cleaner, thats gonna do more damage than good.
Dave DND
QuoteI wouldn't even bother with a laser cleaner, thats gonna do more damage than good
:y :y :-X
will_v6_cdx
i have taken apart could see any dry joints. so put back together but now says
magasine and wont eject or play cds
any ideas?.
Quote from: will_v6_cdx on 06 November 2011, 17:22:23
any ideas?.
Are you now saying that the cartridge is jammed???
will_v6_cdx
not sure. how do get it out if its jammed?. when you try and change frim radio.to cd it just says magasine on digital display.
