Author Topic: EML light flashing then loss of power at high revs  (Read 1586 times)
jsp225
  • Northampton
    • 3.2 v6 special
« on: 31 October 2011, 10:55:16 »
Hi
I just got my op_com, codes read as follows P1870 (2) torque converter clutch stuck off,
P0420 and P0430 Active was catalyst system below threshold bank 2.
Cheers
Re: EML light flashing then loss of power at high revs
« Reply #1 on: 31 October 2011, 20:42:16 »
Dont give use half a story.
What are the symptoms, and what are all the codes in the drivetrain.
jsp225
  • Northampton
    • 3.2 v6 special
« Reply #2 on: 01 November 2011, 08:03:26 »
My 3.2 v6 auto lpg has the EML on all the time, if I reset the ECU it comes back after 30miles or so, I put it into sport mode to over take when it got to 6000 rpm the EML light flashed I lost all power and the engine sounded like it was running on three cylnders.  I pulled over disconnected the battery for five mins, after that it was ok then it happened again when I accelerated at high revs. The last time it happened when it changed up a gear there was a thud. There were no other fault codes just the ones mentioned earlier, any help would be much appreciated.
Cheers
« Reply #3 on: 01 November 2011, 09:48:10 »
First thing to do is to drive it on petrol for a week or so and see if any of the problems occur on petrol too, IMHO.
P0420 and P0430 are normal on a 3.2 V6 because the pre-cats fail. Not anything to be concerned about although the lambda sensors can be relocated to prevent the codes being raised.
« Reply #4 on: 01 November 2011, 18:40:22 »
Cheers
Ah, the full story :y
As Kevin Wood says, find out if it does it on petrol - this will help to pinpoint it to a 'standard setup' problem, or an LPG calibration problem.
jsp225
  • Northampton
    • 3.2 v6 special
« Reply #5 on: 02 November 2011, 08:19:17 »
Thanks Guys I will try that out.
