Author Topic: Heater Bypas Valve quick replacement tip  (Read 1718 times)
nostromo
  • lancashire
    • Omega Elite 2.5 Auto
« on: 31 October 2011, 14:38:18 »
Hi yaal,
well, had the usual coolant loss......half a tank within 10 miles, you could see it dripping around the back of the engine about level with the passenger seats! HBV i thought..!!!!!!  Saw some instructions on how to replace by removing the plenum and loads of other stuff estimated a couple of hours. Pretty daunting really.
Anyhow found another bloke who said half an hour and only a couple of bits to remove.........so we tried this one.
Firstly remove wipers. then remove the windscreen bib, you need to lift the bottom w/screen rubber to find the 10 or so little plastic clips that turn 45degrees to release. lift away in 2 parts and lay on top of engine (didn't disconnect the wiring for the washers). unbolt the wiper motor arms (2 screws to the left of the engine bulkhead) one screw right at the back of the windscreen bulkhead, (to get to this you will need to unbolt the long arm from the top of the wiper motor mount, just a nut.) Unplug the wiper motor connector block. (we removed the 3 bolts to release the wiper motor, to help removal, it will still be connected to the control arms assembly by a wiring loom.) we did this to help remove the whole assembly out of the engine bay, it's easier with two blokes as one can hold the now floating wiper motor, while the other feeds the wiper assembly through the maze of pipes and tubes. Once out you will have all the room you need to replace the HBV with out problems. This proceedure took two blokes about 1 1/2 hours hard at it!!!!! but it means you don't have to disconnect all theose pipes tubes and the plenum!
Hope this saves you time and money....
Only thing is after all that, the fkn thing is still leaking from somewhere (so it wasn't the HBV after all).......
Anyone got any other ideas what's causing the leak, it drips alot from the back of the engine but viewed from under the car the drips are both sides and level with the passenger seats.........so it's traveling to back there from somewhere!!!!!!
Ideas???
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Heater Bypas Valve quick replacement tip
« Reply #1 on: 31 October 2011, 14:50:20 »
I only remove the wiper arms and scuttle when I do the HBV but I have got quite small hands.  ;)  The wiper motor digs in the backs of your hands but not too bad a job. Different people have different methods I suppose.  :y
Regards
Alan
sandune
  • Essex Southend
    • 2.6 Omega Auto
« Reply #2 on: 31 October 2011, 14:59:47 »
Have a look at the hose that go to the coolant bridge from the hbv.
It's the larger of the three hoses and can be chafed.Also not unusual for the coolant bridge to leak. :y
nostromo
  • lancashire
« Reply #3 on: 31 October 2011, 15:22:30 »
Ah coolant bridge...........bloody plenum off for that one I believe!  :-\
YZ250
« Reply #4 on: 31 October 2011, 15:30:25 »
Might be worth pressure testing first to see if it narrows it down a bit.  :-\ Don't know if this guide will help but worth a go I suppose.
http://www.omegaowners.com/forum/index.php?topic=90598.0
« Reply #5 on: 31 October 2011, 16:52:16 »
Its sub an hour to do by removing the plenum.....plus you get to inspect all the other pipes etc at the same time.  :y
« Reply #6 on: 31 October 2011, 19:08:36 »
Easy fixes - hose from HBV to coolant bridge, coolant bridge seals, and oil cooler plate.
Hard  fixes - head gasket, core plug
HTH
bored bigyin54
  • south wales
    • black beast
« Reply #7 on: 31 October 2011, 19:57:47 »
same as mine middle pipe on the coolant bridge was a split just behind the clip
amba
  • Medway towns
    • German V6
« Reply #8 on: 31 October 2011, 22:40:25 »
Same here. ;D ;D ;D
Large coolant pipe to bridge had chaffed where spring clip held it tight :'(...only evident when system had pressure in it..quite straight forward just usual gubbins to remove and refit ::)...worth replacing coolant bridge seals and good time to inspect all the other pipes etc at the hard to reach places....actual pipe is les than a tenner from VX so that and coolant is the only cost :y......plus time  ;D.
Page created in 0.094 seconds with 16 queries.
