Author Topic: no radio and no diplay on 2001 omega estate  (Read 2526 times)
Studs-Ramrod
  • Glasgow
    • 2001 omega 2.2 estate
« on: 31 October 2011, 21:18:48 »
Hi iam new to all this, I was changing the dashboard bulbs and when i put every thing back together i dont have a display screen or sound from cd/radio, radio still lights up. :-[
Re: no radio and no diplay on 2001 omega estate
« Reply #1 on: 31 October 2011, 21:24:26 »
What radio?
Also, check the fuses (cant remember which does display, sure someone will be along shortly)
Studs-Ramrod
  • Glasgow
« Reply #2 on: 31 October 2011, 21:48:54 »
its a cdr 2005 vdo
Mort
  • Bracknell
    • 1999 2.5 Elite (Auto)
« Reply #3 on: 31 October 2011, 22:06:45 »
I had that when I took my dash apart recently.  The radio was only partially plugged back in.  I took out the radio and the cradle, made sure the radio was plugged into the cradle first and then put the cradle/radio back in place.  The radio was getting power, which was why it lit up, but because the display part wasn't plugged in I couldn't see it was in safe mode, which is why it didn't make a sound.
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #4 on: 31 October 2011, 22:15:39 »
when you say dashboard bulbs which ones ?
the ones for the speedo etc or the climate control ?
Studs-Ramrod
  • Glasgow
« Reply #5 on: 01 November 2011, 20:09:57 »
It was the speedo and the fuel gauge bulbs i changed
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #6 on: 01 November 2011, 20:49:58 »
when the dash was put back in, did you put every plug back on, make sure you did not bend a pin in plug. would start from begining.
Solar charger fitted.
If not Broke dont fix it..
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
« Reply #7 on: 07 November 2011, 20:29:49 »
dash might just want a firm push in to position
