Author Topic: Wireless network  (Read 2795 times)
Taxi_Driver
Wireless network
« on: 05 November 2011, 07:11:49 »
Why does my internal wireless network run sooo slow?
For example, i can download a 300Mb file from the net and it takes 3 or 4 mins
But then copy the same file from pc to pc and it can take 15mins  :(
Both pc's connected wireless to the router......maybe its a rubbish router  :-\
Re: Wireless network
« Reply #1 on: 05 November 2011, 10:46:25 »
Few reasons to cause it, though that does sound excessive.
A Wifi works like a 54Mb network hub - half duplex, and no segmentation
Presumably Windoze, thus that effecient download will need each packet wrapped up in a nice big SMB wrapper when copying
Taxi_Driver
« Reply #2 on: 05 November 2011, 12:18:46 »
Ahh.... thankyou for the explanation  :y
Yes both pc's have XP on them......i was expecting it to be the other way round......ie faster internally than the net.
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
« Reply #3 on: 05 November 2011, 16:56:45 »
Or somebody else also use your network and get it slow. You pay while he's downloading free... :-\ :-\ :-\
C20NE - X25XE
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #4 on: 05 November 2011, 17:01:34 »
could you be getting cross signals from another wifi connection locally?
check it using inSSIDer from metageek
Taxi_Driver
« Reply #5 on: 05 November 2011, 18:45:23 »
Thanks for that......downloaded and installed....there is one of those BT openzone's within range of me.....but thats on channel 6, im on channel 1......will keep an eye on it, coz usually theres 5 or 6 wifi networks within range of me, but they don't seem to be turned on at mo....
Taxi_Driver
« Reply #6 on: 05 November 2011, 18:51:37 »
Doubt it tbh, not unless they can break the encryption......and if i check usage on my isp's website...the only time theres a lot of traffic is when im downloading.....other times there minimal traffic.....
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #7 on: 06 November 2011, 09:37:03 »
What incription are you using ?
If its WEP, it can be broken with the right bit of software  ;)
Best to use WPA2  :y
Its a lot harder to break  ;)
Just a thought  ;)
« Reply #8 on: 06 November 2011, 11:14:00 »
Best to use WPA2  :y
Just a thought  ;)
Its been ascertained that nobody else is using it. IF they were, his internet speed would be suffering ;)
For info, WPA has been broken as well, WPA2 probably won't be far behind.  Most people can't use WPA2 because many devices cannot support it.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #9 on: 06 November 2011, 11:29:26 »
Best to use WPA2  :y
I bow too your greater knowlege  :-X :-X ;D
Just a thought  ;)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #10 on: 06 November 2011, 11:32:07 »
Must remember to type BEFORE I hit the button  ;D
What I was saying is  .................  you learn something everyday  ;D
Taxi_Driver
« Reply #11 on: 06 November 2011, 17:30:12 »
Best to use WPA2  :y
Just a thought  ;)
According to my network card in my lappy, network authentication is WPA2-PSK / data encryption AES
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #12 on: 06 November 2011, 23:03:20 »
If you're using WPA2, then it is very unlikely that someone is "sharing" your wifi...
Running at full speed, you should be able to transfer a 300MB file in around 45 seconds (assuming I have done my sums right), this presumes that everything is running very efficiently and it is the only traffic on the network at the time...
« Reply #13 on: 06 November 2011, 23:07:21 »
Just a thought ... what antivirus do you have, and how is it set .. on each machine ???
It is possible that the AV is scanning the file as it is sent on the "donor" machine, and the other AV is also scanning it on arrival on the "receive" machine.....  this could cause a slowdown in transfer.
« Reply #14 on: 06 November 2011, 23:30:46 »
Can you temporarily link the machines using Ethernet to eliminate or otherwise the wireless LAN?
